mhelin
Datasheet p. 19 chapter Audio serial port operation:
"... In Master mode, the BCK and LRCK clock signals are outputs, derived from the system clock input, SCKI. The BCK clock is fixed at 128fS for Single Rate sampling mode."
On the next page about the same on slave mode (I take it that its not recommended as performance may degrade).
Single rate means rates below 54 khz, ADAT wants 48khz. At 96 khz 64fs bit clock is possible.
