Val_r
What is the pitch of this connector, 0.15 inches, right?
500 MODULE SERIES SPECIFICATION
Overall Specifications:
CARD EDGE 15 PIN .156" SPACE
306-015-520-102 EDAC type
EDGE CONNECTOR PIN OUT
TERMINAL FUNCTION
1 CHASSIS GROUND
2 OUTPUT + (+4 LEVEL)
3 OUTPUT + (-2 LEVEL)
4 OUTPUT -
5 COMMON
6 525 STEREO LINK
7 INPUT- (-2 LEVEL)
8 INPUT- (+4 LEVEL)
9 INPUT+ (-2 LEVEL)
10 INPUT+ (+4 LEVEL)
11 GAIN TRIM RESISTOR
12 +16VDC
13 POWER SUPPLY COMMON
14 -16VDC
15 +48VDC
Maximum Power Consumption Per Unit: +16VDC@130mA
-16VDC@130mA
+48VDC@5mA
Size:
Front Panel 1.5”x5.25”x.125” Thick
Depth to Rear From Mounting Surface 5.938” +/-.02”
briomusic said:from API spec:
