DaxLiniere
Hey guys,
I'm modifying a 4-ch headphone amp, adding in a microphone & preamp for talkback.
I'm using a relay to switch the talkback mic, but I've found that when I energise/de-energise the relay, there is a loud *CRACK!* in the headphones' output.
The headphone amp PSU is 7815 & 7915. The mic preamp is powered from 7815 thru resistor for 12v. The relay is 12v, but running from 15v directly from the 7815 output.
Can someone suggest a solution to my problem, please?
THANKS!
THANKS!
