mrclunk said:currently i've resorted to cleaning between the knobs and switches on our desk with cotton buds.
That's a fun job !!
Clean your ears while you have the "buds" out !!
MartyMart said:Clean your ears while you have the "buds" out !!
rob_gould said:Olive oil is the only thing you should ever put in your ears at home to help soften up the wax and let it drain away naturally.
Abstract
Ear candles are hollow tubes coated in wax which are inserted into patients’ ears and then lit at the far end. The procedure is used as a complementary therapy for a wide range of conditions. A critical assessment of the evidence shows that its mode of action is implausible and demonstrably wrong. There are no data to suggest that it is effective for any condition. Furthermore, ear candles havebeen associated with ear injuries. The inescapable conclusion is that ear candles do more harm than good. Their use should be discouraged.
