GSSL CRC Board from Expat Audio
The brand of transformer and your location won't matter as long as you've wired your primaries and secondaries based on your country's power so that the correct voltage is getting into the CRC. If something is still burning after you confirm correct voltage on the secondaries then you have a bad solder connection or component placement somewhere on the board.
Paul
