robomatique
Tube sockets for G9?
« on: November 21, 2004, 09:21:18 AM »
Hello,
I am soon finished with my G9, but I ran in to a small problem. I think I bought the lab's G9 board, but it might be Gustav's, and I can't get the tube sockets to fit the board. The socket pins are flat and the holes aren's wide enough.
I have tried to find a socket with round pins, but I can't find any (and it is hard to see on small pictures on the net. Does anybody know where I could find something like this, preferrably in the UK or Europe?
I guess I could try to make the holes bigger but I am worried I will ruin the solder point in some way, the rest of the board is already stuffed and I don't want to loose it.
Robert
"Trying is the first step towards failure."
-H. Simpson
mcs
« Reply #1 on: November 21, 2004, 09:34:49 AM »
I think you can get sockets that fit from Farnell. The ones I have are from Triode Electronics in the US...
Best regards,
Mikkel C. Simonsen
gyraf
« Reply #2 on: November 21, 2004, 10:05:31 AM »
Or you can drill the PCB holes a bit larger. Or possibly cut off a bit of the socket pin's width.
The problem is that there's no standard size for tube pcb sockets..
Jakob E.
[email protected]
« Reply #3 on: November 21, 2004, 01:38:53 PM »
Here is a twisted idea. Twist the pins a little while pulling on them. I have succeeded fitting them into boards this way while destroying only a few of them.
robomatique
« Reply #4 on: November 21, 2004, 02:00:25 PM »
Thanks for answers !  :grin:
I have tried to cut the pins to a narrower width but that didn't work. I will give it a try to twist them, but I don't think it would work (I think I tried that).
If I am going to drill bigger holes I am just worried that the path would get destroyed and make a much bigger problem...
So if anybody knows of anything please shout, otherwise I will just see what I can do.
Thanks again guys! Extremely helpful as usual :grin:
Robert
-H. Simpson
Smoke
« Reply #5 on: November 22, 2004, 12:47:01 AM »
Quote from: "[email protected]"
that made me fall of my chair (:
i just bought 4 of these and im stuck with the same problem.
actually i have two problems. they have extentions so you can screw the socket onto the PCB, and the way it has to be rotated to fit the pins is tough because theres other parts in the way.
then the pins are flat and wierd.
oh well
rfmaster89
Tube Socket info for PCB mount
« Reply #6 on: February 06, 2006, 12:38:42 AM »
Regarding tube sockets. I am searching high and low for manufactures drawings for PCB 9 pin socket NOVAL R9A for 12AX7 / ECC83. In order to design a correct PCB layout an engineering drawings for a socket must be on hand. I have not found any such source for drawings - any leads would a great help .....
RF
gyraf
« Reply #7 on: February 06, 2006, 04:32:06 AM »
Quote from: "gyraf"
Jakob E.
MrZpliff
« Reply #8 on: February 06, 2006, 10:47:44 AM »
I used a small file (the tool - not digital)  :wink:  and carefully filed each pin down until it fitted....
Peace
Magnus
www.bitterend.se
tony dB
« Reply #9 on: February 07, 2006, 04:57:08 AM »
when doing mine, I took a cuttertool to make a dip in the pin, parallel with the edges of the pin. Then I folded the pin, using nosepliers so the result was a pin half the size with more connecting surface. Unfortunately a few socketlegs died in process, which I solved by soldering a twisted resistorleg to the leftover bit of the connector. These thru the pcbholes soldered to pcb. vwalla.
Tony.
Last post April 07, 2007, 04:33:33 AM
by b2
Last post April 01, 2009, 01:45:28 PM
by kazper
Last post January 02, 2012, 01:16:56 PM
by VacuumVoodoo
Last post April 01, 2019, 01:26:15 PM
by Tubetec
