ioaudio
Shop closed, working on the next batch
MK-U47 Tube Microphone Kit featuring:
Costum Headbasket made by Flea with Pattern Switch
Brass made body tube and bottom bell, bead-blasted and nickel-plated
Stainless internal structure
Bv.08 Transformer with 8 seperate sections from my own production
My dual 6028 tubes single supply circuit
including:
body tube
bottom bell with power resistor mounted + internal structure
Headbasket pattern switch
Transformer + resistor board
High-Z board with screws, teflon isolators, shims for variable capsule mount height
solder lugs and subminiature reed-contact
Black rubber band for tube shock-mount
Tube deck + tube sockets, screws,
Wiring, yellow wire sleeve, shrink tube
Binder connector for mic and cable
Bv.08 Transformer
PIO and styroflex capacitors, resistors
To complete the microphone, you'll need:
2 x 6028/408a tubes
a capsule + holder
a single supply 105v PSU
a microphone cable (cable connector to mic included)
SOLD OUT
including:
body tube
Bv.08 Transformer
2 x 6028/408a tubes
a capsule + holder
SOLD OUT
