ihscoutlvr74
- Joined
- Apr 2, 2008
- Messages
- 68
Gents,
I've read 40+ pages of the LA2A meta and still have a voltage anomaly. I have followed some of CJs mods I found and removed the limit switch and response pot.
All of my voltages are very close except for the grid and plate voltages on the 6AQ5. This seems to be a common issue but here's my values-
as per 1968 schemo
R34 - 10k, 3w
R36 - 470r
R38 - 22k
6AQ5
pin 5 - 124v
pin 6 - 139v
pin 2 - 7.3v
In the meta I read that pin5 should be approx 90v. Would using the 22k and 1k for the resistors, removing R38, and changing the cathode cap value solve this issue or is there something else I need to address? BTW I'm using JAN 6005 Sylvania for 6AQ5 if that might change any readings.
The unit passes audio fine and does compress some but I think the el panel(diy night light/nsl-5910) isn't lighting fully and wondered if the off voltages may be to blame. Has there been a night light or other commonly available that has worked best for others?
Thanks, Nathan
as per 1968 schemo
R34 - 10k, 3w
R36 - 470r
R38 - 22k
6AQ5
pin 5 - 124v
pin 6 - 139v
pin 2 - 7.3v
Thanks, Nathan
