clintrubber
How different is the polar pattern over frequency of ribbon mics
(say R-121... or... actually the ACM-3 ) w.r.t. sounds coming from the front or rear,
off-axis from above/below or from the sides ?
(both well away from the inherent fig-8 null)
( Attached pic of the ideal 3D-polar fig-8 plot )
Could be re-formulated as:
would the sound change much when the mic would not be positioned vertically but now horizontally ?
(so the actual ribbon still oriented in the same plane,
but now it's rotated 90 degrees in its own plane).
This results in the '8' of the picture being rotated, but still occupying the same space.
Could imagine this would result in a changed off-axis pickup over frequency... what do you think ?
Background of my question is if it'd be OK w.r.t. the stereo-image to re-position the lower-mic of a Blumlein setup like this.
Peter
Peter
