UTC LS 140
CJ
GDIY Supporter
California
says there's a free prize inside, .....so what do you think?    :p :p :p :p :p :p :p :p :D
oh boy!  open the box, open the box, open the box
this stuff is a trip CJ-
I wish I had a better handle on physics, but I'm having a bad math life.
math is the language of all sciences.  i feel illiterate.
open the box before i get depressed(er).
Gee you're a busy lad at the moment CJ.
I would bet every audio trafo within a 50 mile radius of your house is afraid.......very afraid!!!!!
Mac  ;D  ;D
ok same ol thang, only different
http://i37.tinypic.com/33586x1.jpg
http://i38.tinypic.com/2rm8oyf.jpg
http://i37.tinypic.com/x6dhl0.jpg
http://i33.tinypic.com/eirs5v.jpg
this thing turned out to be pretty weird, look at it, all messed up, sittin there like a poodle,
workin those leads like a schoolboy,
ok, so it Is another 31UI, wtf, over? plus, they forgot one of the coils, i am going to call UTC,  :D
looks like a record player motor, weird, eh?
this is a Hybrid transformer, so spell the lams accordingly,
this is something i have not seen since i worked at Aydin Energy building transformers,  folded shields:
so that center winding in this pri-sec-pri rig is buried under two copper shields whose ends are tucked,
this keeps cross talk down to about -92 db , catalog spec,
more weirdness, bi fi windings, this is the splice from the outer pri to the inner pri,>
shield connection looks serious,
heavy cardboard in between pri-sec, another weird tweak. usually you want  copper in the window,
how do they wind these things? slowly.. we use to put a piece of mono fish line in between, better C,
there is a piece of copper in there, inside the yellow mylar, it gets wrapped around the leads,
first layer.  all thw windings are bi-fi,  200t - 400f- 200t, so twice that = 800 turns , pri, 800 sec.
i  will get the spread sheet up shortly...
