Colin was very kind to send me one of each. Did not test these "scientifically" but I've run a quick test, by attaching each one to the output of the DAOC. I have to say it was not "proper" DAOC just P2P test version,
that I assembled in order to see "do I need this comp at all?". I do. It is very good compressor (I run full Kubi mods apart from input transformer that I kept 1:1). Input transformer is 10k:10K, that I wound my self on Stancor core, from disassembled 4:1 Stancor input transformer.
Gapped Carnhill:has roll off starting @~10k and reaches ~ -0.3dB @20k so i would consider it to be "flat" 20Hz-20kHz.
Ungapped Carnhill: I would consider it to be "flat" from at least 20Hz-30kHz.
Test was done thanks to RMAA and m-audio audiophile 2496 in 96K mode, no high end pro equipment, as you can see. No zobels on either transformer secondary.
Both transformers sound good to me, but that is just my opinion. I like color and DAOC circuit has dominant 2nd
harmonic distortion (~0.1%@+4dBu 1kHz) that gives very nice, "full"&"fat" sound (whatever that means) with soft and round "edges" but it is not "dull" nor "damped", again IMHO.
Gapped has a bit reduced F.R. due to the "gap" and less inductance, and I don't think it is fair to test it like this as it is relay meant to be used in the situation where DC is present @ the primary, which is not the case here. I have no such a circuit at hand, at present.
I ordered some more transformers from Colin yesterday, as I'll be using those on my forthcoming builds.
Best
Milos
