snipsnip
Hi Guys,
Ive got a few questions regarding amp draw on my DIY dual Pultec. Just so you know, I have worked on several projects that run off mains, but never one with high voltages on the circuit. The pultec project is not hugely well documented like some other popular DIY builds, and with no BOM to work from, Im having to really think about amp draw for the first time.
The fuse on the PSU / Make up gain PCB is marked as 4AT. I guess this means 4 amp. Im a little unsure on this as the schem seems to say something different.
http://www.sowter.co.uk/schematics/gyrafeq.htm
First, of course, I need to validate that the above assumption of 4a is correct, otherwise the following calculations will be invalid. However, assuming the PSU does require a 4a fuse, does the following hold true?
1) I want to take the power from the mains to a switch before the torroid. As Im building a dual unit, this means I need to take live & neutral ‘twice’, so that after the switch I can go to 2 torroids. The cable I have is only rated to max of 6 amps. So am I best running 2 sets of cable in parallel (one for each torroid, assuming draw of 4amps each?).
2) I have a chunky on off toggle switch which is rated at 10 amps @240v, so I assume this is fine?
3) When I choose a fuse for my mains socket, I guess I need to simply double the draw of each PSU circuit. Given that Ive also got a little power lamp to run, will an 8amp fuse be sufficient (lmap is 24v, but dont have any other info)?
I know these are high voltages and potentially lethal circuits, which is why I don’t want to rely on a single assumption, so appreciate any thoughts. Im know some things about DIY electronics, but certainly don’t have the overall grounding in the subject matter to have much confidence in my logic!
Jake
Jake
