If I increased the B+ to ~250Volt and played around with the anode resistors, is there any reason the PRR wouldnt work if I replaced the 12au7 with a ecc/pcc/ucc85? http://www.cicognani.eu/pdf/Tubes/ecc85ph69.pdf
I do love my PRR varimu the way it is, but always looking for different flavors and have been thinking for some time about building a second unit.
the UCC85 (100mA/26Volt heater)is dirtcheap and easy to find (at least here in Sweden) and seems to be well liked in the Chiswick Reach comps(they use the 300mA/9volt heater version)
obviously, the tube sockets will have to be separate from the PCB that many people have used. (the copper tracks are a little close for 250volts, I believe)
will the sidechain be able to chut these tubes off?....I realize just changing a tube wont turn it into a Phoenix, but will it work?...
any thoughts?
johan
any thoughts?
johan
