HI, I guess 6au6 (or even an EF86, as on your schematic) may present a very High output impedance to the outside world... To achieve the about 20db gain and usable output impedance of the original 5532 stage with tubes while keeping the design quite simple, I think I'd rather use a low/medium mu double triode (such as a second 12AU7) and go for example for a grounded cathode stage for voltage gain followed by a cathode follower , or a SRPP stage, like on the output of Gyraf's Gpultec, or the one of the G9, or the Slowblow...
You could achieve enough gain with the 6au6 triode connected, and a more useable output impedance, still not very good, but perhaps good enough for a 10k soundcard input...
But I guess you have the 7 pin socket, and the 6AU6 already in the box... I don't know any 7pins double triode... but I think swapping a socked shouldn't be a big deal...
Or, perhaps you could find an esotheric old 7 pins small power pentode with low enough Rp... ( but I'd expect a fairly high THD) .
Laurent.
