Excellent! Yeah Il be in for 1 or 2 depending on price. I have always wanted to try a 500 series DIY Also, if you have two separate units, what is the accuracy like in regards to EQs when using them in stereo pairs even at the same settings?I have never used two separate EQs as stereo unless they are a stereo EQ unit already so I am wondering whether they are as sensitive as using two separate mono compressors in stereo, do they have to match components somewhere for each EQ?Thanks
Hey thanks that's a good one " as she pensively ponders , Will one eq ever be enough ? "yeah and you know they copied that california bandsomething about feeling noise .
Quote from: briomusic on November 01, 2009, 10:42:28 AMis this going to be 51x or standard 500 format?Probably standard, with a dc/dc converter.
The lovely Ed Anderson is having a pop at smallifying the LO1166.
Started by onlymeeee « 1 2 ... 37 38 » Preamplifiers
Started by Igor « 1 2 ... 6 7 » The Lab
Started by mikefatom « 1 2 3 4 5 » The Lab
Started by Whoops « 1 2 » Black Market
