TheGuitarist
So my pro tools controller idea was a bit bust, kinda annoying to find that digi has such a strangle hold over what controls pro tools. Ah well, the information is now there for others.
But the whole making a console thing got me thinking... i mix ITB but i still need a good front end.. so why not make a console dedicated to tracking.
My idea was to use either 1290, 312 or ssl 4k/9k pre's (havent decided and i'm trying to work out what would be the best, or if i should mix and match etc.)
as the preamps with JLM go betweens for the main part, then either a neve 1084/1073 EQ or a pultec clone with both the eqp1 and the mid frequency one as well, it'd be a monster but way cool.
Then just use LED or trad VU meters from the output and then send the outputs to a patchbay which when not in use gets normalled to balanced direct outs, or can be patched into various compressors also built into the console.
So my questions would be, do i still need an output amp if i go the pultec route? and do i need transformers left right and center to get this work, or can i work with just input transformer on the pres and then an output on the direct outs after it gets sent there or through a compressor.
If this goes ahead it will probably be a do a bit at a time build but i think its a cool idea. Anyone have any suggestions or pointers?
