Re: DIY mic pre based on Studer 169 (DOCUMENTS PUBLISHED FINALLY)
« Reply #40 on: May 12, 2013, 07:10:28 PM »
 Have you posted these to the technical documents ? Thanks  [ I always liked the studers ]
glover
« Reply #41 on: January 20, 2014, 12:53:59 PM »
I have same question as dirtyhanfri, what's the value for L1 ?
dirtyhanfri
« Reply #42 on: January 21, 2014, 12:55:52 AM »
I'm wondering if it's like in Green pre or Tac Scorpion preamp,  just a jumper in a ferrite core?
Working on it...
Spino
« Reply #43 on: January 21, 2014, 06:49:06 AM »
i've been trying to find out as well. studer original bom and schematics don't report those values (oh and btw, studer original has another L post trafo pre amp stage and a double L pre trafo). from audiox's component layout values pdf it looks like it's marked as FER, so i'd guess a ferrite bead. a friend of mine has one and i'll try in the next couple of days to take a look and get a measure.
darkcharly
« Reply #44 on: June 30, 2014, 02:13:00 AM »
Do you have any news on the L1?
Anyone? ???
« Reply #45 on: June 30, 2014, 05:26:04 AM »
62.01.0115   2.5Wdg   Wideband choke
darkcharly
« Reply #46 on: July 01, 2014, 03:25:37 AM »
Thank you ijzerpro !!
Spino
« Reply #47 on: July 01, 2014, 10:55:40 AM »
Anyone? ???
ooops, totally missed this one, sorry.
yes, original L where Philips p/n 62.01.0115. they can be changed with TDK p/n B82114-R-A4.
in italy, they can be found at Distrelec with code 350214.
as for the original common mode choke before the original trafo (parts L1A and L1B on the original studer schem) each single coil measures about 240 mH, and ferrite is indicated as 3E3. no ideas on the wiring though, and no idea of what could come close to that.
hope it helps. any further infos would be great!
darkcharly
« Reply #48 on: July 02, 2014, 02:24:40 AM »
Anyone? ???
Spino: Of course it helps! Thank you very much for the info!
« Reply #49 on: November 01, 2014, 06:39:25 AM »
What about 1:2 xformer?
Age Of Leviathans
shot
« Reply #50 on: January 21, 2015, 10:52:50 AM »
I went to re-read this thread. Maybe considering doing it.
I'm confused on one thing. Audiox wrote it's a double-sided board, but in the build documents there's only one-sided pcb copper mirror. Is this copper mirror okay? PCB is one-sided etch, yes?
Difficult part seems to be L1 choke. Does anyone know what is the value of this inductor in henries?
I found TDK B82114-R-A4 on Mouser, but Mouser is very expensive in my country. Too expensive if I want to order just few pieces. I may try to find substitute that I can get locally.
« Reply #51 on: February 03, 2015, 06:07:49 PM »
The first layout version was double-sided, the final single-sided.
Almost any ferrite bead should be fine. In the unlikely case of oscillation, add turns.
SoundOfRolf
« Reply #52 on: May 21, 2015, 01:47:56 PM »
Awesome pre! If anybody would be up to transforming this into a 500 series pre I'd surely offer them a beer or two.?
Or should i just go ahead and order that protopcb from AML. :)
Anyways excellent work Audiox and the 169 Eq is next on my building list.  Don't know how to thank you enough so thumbs up!
-Forever lurking
EDIT:
For anyone interested there's a new thread:
http://groupdiy.com/index.php?topic=59616.msg756998#msg756998
« Last Edit: June 05, 2015, 04:20:28 AM by SoundOfRolf »
nhaudio
« Reply #53 on: July 19, 2016, 05:27:43 PM »
 could somebody post their voltages? I'm having trouble with my self etched board. Probably a bad connection but can't seem to find it. Voltages would help a lot. Thanks
Last post January 16, 2007, 03:21:17 PM
by q2audio
Last post March 15, 2007, 08:16:23 AM
by Paul Fury 161
Last post March 31, 2007, 02:56:59 PM
by manarm
Last post March 10, 2018, 02:28:53 PM
by jon83
