G
Guest
Guest
Hi folks,
I'm posting this at the seventh circle forum too, but I figure I can use all the help I can.
I recently finished an a12 card, but the phantom wouldn't work. Doing the molex connectors, I may have very well shorted one a b+/- to ground, blowing a fuse. At this point it's been a awhile, so I'm a little hazy with the play by play idiocy of that day.
In any case, the card is powering up, and there's proper (+/- 18v) at the pins for the opamp (1122 Avedis), but when the op amp is inserted, things go wrong. Mainly, I get a pulsating, chugging bit of sound at the output. It definitely sounds the way a wave looks on a screen. I think. Yikes. And, the opamp (and the card in general from what I can tell) also starts to heat up.
The obvious novice reaction is blown opamp. Has anyone fried an opamp, and did have similar symptoms at any point?
I really can't wait to get this thing done, so I can move on to the SSL!!
Thanks for any ideas...and have a good Thanksgiving.
Kelly
Kelly
