Re: Studer 169 EQ in API 500 format
« Reply #440 on: August 05, 2017, 01:03:29 PM »
No DOAs. Just the four 5534s. But I accidentally hooked 16v to the DOA hole in the middle.
In that case, test the voltages on the circuit without the ICs inserted...
Gustav
« Reply #441 on: August 05, 2017, 01:05:01 PM »
Great! I new to this so what can I expect to find?
« Reply #442 on: August 12, 2017, 04:40:15 AM »
I'm still battling these. I've built two and both of them are acting up in the same way. I've even had a really experienced tech look at it and he can't figure it out. He said all the voltages are looking ok and signal is passing through.
What's happening is the frequencies being all messed up. All three are acting weird.
Bass filter: if I send a 10khz sinewave in to the eq I can boost or the signal a couple of db which seems weird.
High filter: same as bass filter but the other way around. I can boost or cut a 20hz sine wave a couple of db.
Mid filter: Barley boosting when set to 150hz but the higher frequencies I choose the more I can boost.
I can't figure it out and it all just seems weird. What have I missed? What can I check for? Busted caps? Resistors?
Help!
« Reply #443 on: August 13, 2017, 08:55:46 AM »
Anyone? Please..
« Reply #444 on: August 13, 2017, 01:28:12 PM »
Anyone? Please..
Its really odd that a tech could not pinpoint any problems.
If voltages are good, then you may have something set up incorrectly for the DOA vs IC configuration.
...or maybe the pots are not right...
Gustav
« Reply #445 on: August 13, 2017, 03:19:34 PM »
Could it possibly be the extra LED that is causing this?
The pot are the right ones and I'm not using any DOAs just the ic.
« Reply #446 on: August 14, 2017, 06:24:59 PM »
The low filter peaks at low frequencies, nominally 20 Hz.
The high filter peaks at high frequencies, nominally 20 kHz.
The mid filter peaks at 150 Hz - 7 kHz, depending on the frequency knob setting.
The test signal should match the frequency you are modifying.
Maybe it works just fine.
« Reply #447 on: August 15, 2017, 02:56:25 AM »
It doesnt work fine unfortunately.
If I send a 150hz test tone in to the eq and set the eq to modify 150hz nothing happens. But if I leave the eq setting to modify 150hz buy change the test tone to 3khz it's boost A LOT more.
The bass filter boost equally much at 3.6khz as it does at 20hz. That's can't be right, can it?
[silent:arts]
« Reply #448 on: August 15, 2017, 04:16:41 AM »
Check the values of the frequency setting capacitors.
« Reply #449 on: August 15, 2017, 05:01:40 AM »
Which is that exactly?
I've check and rechecked all of them 10 times by now. But maybe I'll just swap them. Which ones are the frequency settings capacitors?
« Reply #450 on: August 15, 2017, 07:00:44 AM »
I believe I solved it.
The store sent me 6k8 resistors instead of 680k. Never bothered to double check them before inserting them.
I havent tried it out yet with the right resistors, but it makes sence.
Thanks guys for your help.
« Reply #451 on: August 15, 2017, 05:24:40 PM »
So I replaced the faulty valued  resistors and it now works and sound amazing!! (Surprise...  ::))
Thanks Audiox and Gustav for a great eq!
Over and out.
Siegfried Meier
« Reply #452 on: October 24, 2017, 10:41:52 AM »
I'm brutally colorblind so I'm always forced to measure resistors first...it's probably a blessing in disguise.   ;D
Over and out.
kante1603
« Reply #453 on: October 24, 2017, 11:02:33 AM »
I always check all parts that I'm able to check before assembly.....and I mean that.
Udo.
peterc
« Reply #454 on: October 24, 2017, 11:57:30 AM »
Learnt the hard way to check resistor values with a meter before insertion
Red and Orange can look very similar on some brands of resistors
Good to check the caps as well, gives an extra level of confidence to your builds
Peter
If opportunity doesn't knock, build a door.
« Reply #455 on: October 28, 2017, 05:17:03 AM »
 Can I expect a volume drop if I build this eq without the transformer?
As soon as I engage the EQ the level drops significantly.
If it’s not the lack of transformer, what might it be?
« Reply #456 on: November 22, 2017, 04:19:35 PM »
Hello again.
Would changing the two 20k resistors to 22k make a big difference. I didn’t have any (and still don’t) 20k resistors at the time, so I popped 22k in instead. Could this cause my big volume drop?
Potato Cakes
« Reply #457 on: December 08, 2017, 01:46:25 AM »
Do you have 10K resistors? If you do just use a pair of those in series to get to 20k.
Paul
dustbro
« Reply #458 on: January 23, 2018, 08:47:49 AM »
Took a quick peek at the new schematic. C3 and C7 polarity appear to be reversed from the original schematic. Mistake? or is the original wrong?
« Reply #459 on: March 13, 2018, 04:40:07 PM »
Hello everybody,
I’m about to build a pair of the 169 EQ. Since the dual 100k rev log potentiometer (P4) is a bit hard to find (apart from ordering from AML), I was wondering if I could ‘simulate’ it with a combination of a dual lin pot and a resistor. I’ve read a few pages about it, but for the life of me I can’t figure out the correct math. Could anyone in the know help me out? Which values do I need for the linear pot and the resistor? Or would I need two resistors here for the dual gang pot? And how do I go about the correct wiring?
Sorry if this has been discussed before. It’s hard to find the answer to a specific question when you have to browse dozens of pages... ;)
Claudio
Last post February 27, 2006, 02:05:19 PM
by gar381
Last post August 12, 2010, 05:22:26 PM
by livingnote
Last post December 11, 2018, 07:01:23 PM
by Bonsaimaster
Last post January 17, 2020, 02:01:35 AM
by manulaudic
