strangeandbouncy
Re: Studer 169 EQ in API 500 format
« Reply #80 on: May 12, 2010, 05:34:25 AM »
And again
. . . . RUH ROH . . . . .
strangeandbouncy
« Reply #81 on: May 12, 2010, 05:57:43 AM »
Hmmm,
   you'll have to crane your necks, I rotated the images here and saved them, so gawd knows why they're topsy-turvy!
      AndyP
dmp
« Reply #82 on: May 20, 2010, 03:39:16 PM »
Andy,
What caps / freqs did you use for your 6 position switches? What are you finding the most useful for different applications?
I am an amateur with recording so any insight is appreciated...
Dan
strangeandbouncy
« Reply #83 on: May 20, 2010, 04:08:10 PM »
  in bass, 330nF, 220nF, 150nF, 100nF, 68nF, and 47nF, giving 19Hz, 28Hz, 40Hz, 60Hz, 85Hz and 120Hz.
  in Treble, 47nF, 33nF, 22nF, 15nF, 10nF and 6.8nF, giving 4k1, 5k9, 8k8, 12k7, 18k9, and27k3
   I am using 28Hz and 18k9 quite a lot. I am using them across drum sub-bus post comp, mix bus duties, and especially on vocals.  They are awesome an individual drums too! Kick, Snare and toms - yum!  wish I had not come up/down so much, but had more choice at the extremes really. I wish I had 22k7 especially! I will be doing this on my next pair. I used Wimas for what it's worth. Available at Maplins!
  I would recommend NOT doing what I did if you want something general. The mid band would be extremely useful, and I would be very happy with say, bass set at 28Hz, and treble at 18k9. If you follow Audiox's front panel, and have 3 or even just 2 different frequencies top and bottom, you would be very happy, I am sure.
    I can recommend using API 2520 for this. It definitely adds a certain je ne sais quois . . . I am looking forward to trying the OA10 too! If you want to just use an NE5534, this sounds great too!, but a bit more brittle at extreme gain in the HF.
   Good luck! this is a very simple build, no power supply required if you have an API lunchbox, so very much safer too. It is not rocket science, and you will instantly love them ,i promise!
   Good luck,
    ANdyp
dmp
« Reply #84 on: May 20, 2010, 05:28:48 PM »
Cool! thanks for the advice.
I'll would like to keep the midband, and try to add selector switches for the high and low frequencies.
So maybe...
high: 12nf (15.8kHz), 10nf (18.9 kHz), 8.2nf(22.7kHz)
low: 220nf (28Hz), 100nf (60Hz), 47nf (120 Hz)
(edited to correct typo...)
« Last Edit: May 21, 2010, 09:39:46 AM by dmp »
strangeandbouncy
« Reply #85 on: May 20, 2010, 05:33:36 PM »
Just go for it!
  You can always change 'em to taste . . .
           Kindest regards,
                 ANdyP
Davo
« Reply #86 on: May 20, 2010, 08:37:21 PM »
dmp, you meant "nf" values rather than uf right?
just makin sure
sunmen
« Reply #87 on: May 21, 2010, 03:34:12 AM »
Hi everyone,
Very nice project, and very nice versions you guys !   8)
I've just seen this thread, I'm would be in for two.
Does someone know if some people are gathering for a new batch here ?
Thank you so much and bravo !
Davo
« Reply #88 on: May 21, 2010, 03:41:09 AM »
Hi sunmen,
You can get em from Gustav, here's a link: http://www.groupdiy.com/index.php?topic=10776.0
cheers,
dave
strangeandbouncy
« Reply #89 on: May 21, 2010, 03:42:24 AM »
  sorry, i MEANT nF not uF
   forgive any confusion!
     ANdyP
Davo
« Reply #90 on: May 21, 2010, 03:51:30 AM »
Hi ANdyP,
Naw, you got your values correct :)... just makin sure that dmp doesn't have a bunch of lytcs hangin off the board, wondering
why it's not workin right
cheers,
dave
sunmen
« Reply #91 on: May 21, 2010, 06:30:16 AM »
Thank you very much Dave !
dmp
« Reply #92 on: May 21, 2010, 08:23:36 AM »
Yes. thanks! I typed them wrong
RedNoise
« Reply #93 on: May 21, 2010, 03:07:43 PM »
Hi everyone,
Hi Suman !
Welcome!!Use PM if u wanna be in contact!french guy right??
Sorry for the little hijack...
If your neighbour is hunger : don't give him fish , teach him how to fish ...
if you don't like it don't buy it ;-)  [Wolker Texas Ranger] ( ;-) )
kingj
« Reply #94 on: May 23, 2010, 11:23:40 PM »
So I kind of want to do a narrow/wide switch for the middle band. From my understanding it would just be a switch and a resistor but does anyone have an idea as to where I would want to place this? thanks a lot guys.
Holger
« Reply #95 on: May 26, 2010, 11:36:36 AM »
My next one:
- changed front panel design
- added LED for EQ in
The OPAmps are not final, ignore the violet wire.
Front panel made by Frank Röllen/NRG Recording.
Does anyone know a good source for cool looking small knobs, especially for the 4mm shaft pots?
« Reply #96 on: May 26, 2010, 01:22:01 PM »
gonna need some panels somehow
Do you know how much or mind
if franks sells some more  ?
ethervalve
« Reply #97 on: July 15, 2010, 05:34:52 PM »
I just finished my 169 using ne5534s throughout. What a simple, affordable and great-sounding project--thanks Audiox and Gustav!
Now, if only some enterprising individual were to jump in and start selling cheap and simple front panels...
RedNoise
« Reply #98 on: July 15, 2010, 05:50:58 PM »
skipwave
« Reply #99 on: July 15, 2010, 05:56:20 PM »
Quote from: PRR
Now, maybe you don't, or shouldn't, grab the ribbon for far-harpsichord, nor the hot condenser for snare-kissing... yet often we do.
Last post February 27, 2006, 02:05:19 PM
by gar381
Last post August 12, 2010, 05:22:26 PM
by livingnote
Last post December 17, 2012, 11:20:19 AM
by mulletchuck
Last post December 11, 2018, 07:01:23 PM
by Bonsaimaster
