dmp
Re: Studer 169 EQ in API 500 format
« Reply #480 on: November 05, 2019, 09:31:14 AM »
I am still getting noise when switching.
That doesn't sound right to me - seems you have DC on the output of the last opamp. Maybe try swapping the ICs and see if the problem goes away (U3 & U4). Or you could add a blocking cap but it would be better to just get opamps with the the output Vbias.
About the high frequency - these are pretty noticeable.  You might want to measure the frequency response (I posted some sweeps back on page 9). I'm guessing there is something wrong if you aren't hearing them, especially with the 12k & 16k. The stock 20k is very noticable because the HF boost is full at 20k but has a wide boost all the way into the high mids (~1k ~2k)
dmp
« Reply #481 on: November 05, 2019, 04:55:50 PM »
What discrete opamp do you have for U3?  If it has a offset voltage that's could be the problem. Maybe stick a blocking cap in to test.
dmp
« Reply #482 on: November 05, 2019, 05:04:22 PM »
Does my drawing for the HF switching above look OK?
Looks fine
manulaudic
« Reply #483 on: November 16, 2019, 01:06:58 PM »
I've gone through the thread and there was a mention as though only the mid pot needed to be dual and i traced back the pcb and indeed it seems like the others are working as single pots.
If there anybody that can confirm that it 's be possible to use single pots escept for the mid one?
Manu
TwentyTrees
« Reply #484 on: November 17, 2019, 01:26:39 PM »
Yep!
Manu
manulaudic
« Reply #485 on: November 18, 2019, 03:53:39 AM »
Mid frequency sweep (P4a and P4b) needs to be dual gang. The others can be single gang. If you look at the schematic, 'HI' (Dual 10k Linear) and 'MID' (Dual 10K Linear) are wired so each gang/track is in parallel, so Hi (P2A and B) is working like a 5k single track linear pot, Mid (P3A and B) is also like a 5k single track linear pot. Only one half of P1 is used so it is acting like a single track 22k linear pot. P4 is the only one that really takes advantage of both tracks fully.
Indeed i found this ! i'll go with that
Manu
Indecline
« Reply #486 on: January 08, 2020, 12:47:00 PM »
Anyone found a way to widen the Q on the midband? I’ve messed with it in spice but no luck.
Ricardus
« Reply #487 on: April 18, 2020, 03:55:59 PM »
I really like what I've heard about this EQ so I'll be ordering some boards from Gustav and I'll start with building a pair. I already have questions, but I'll finish reading the thread before I ask.
Audio mastering for hire..
Ricardus
« Reply #488 on: May 06, 2020, 11:29:25 PM »
Question. On all of the FPD files I've seen for this front panel, all of the holes (4 pots and one switch) have 7.5 mm holes. I just measured the shafts on the pots from AML and they're 6.70 mm. Is that extra play because they thought it would be good to have extra room for the 4 pots and one button that has to go through the holes when trying to mount the panel? In case someone's soldering is a little sloppy on the pots? It almost seems like TOO much play.
What is your experience with this?
Ricardus
« Reply #489 on: July 07, 2020, 07:56:52 PM »
I just finished units #3 and #4. They all work, except #4 doesn't work on the low shelf band. You turn the post and I don't hear any frequency change (or if I am hearing something, it's hard to tell, it's VERY subtle). Everything else works fine. Anyone else seen this problem before?
Also, how much of a pop should there be with you engage the EQ? All 4 of mine pop a little. Sometimes depending on program material (I think) it pops a little more.
Last post February 27, 2006, 02:05:19 PM
by gar381
Last post August 12, 2010, 05:22:26 PM
by livingnote
Last post December 11, 2018, 07:01:23 PM
by Bonsaimaster
Last post January 17, 2020, 02:01:35 AM
by manulaudic
