tchgtr
I was given a Dr*wm*r M500 that I have been trying to restore. It originally blew fuses immediately on power up.
After replacing the + and - 15v regulators and a tant cap that read shorted with a DMM, it works, but now blows the fuse on power down.
Does this mean I haven't really found the original source of the problem?
I have no schematic, as D'mer does not wish to give them out.
Once the parts were replaced, it did a self-diagnosis, and works perfectly, other than blowing fuses. It looks like the front right of the case took a big hit at some point, which bent the rack ear back to quite a degree (now fixed), and seems to have been stored near a window during it's downtime, so I had to cut a notch in some of the lid screws to remove the top and bottom covers, as the screws were a bit corroded. Two (of 4) LED/TL072 assemblies inside the case had popped out of their sockets, but were easily replaced. The memory battery had corroded, but was smartly encased in plastic and did little damage. I replaced this with a coin cell and replaced another 'lytic that was nearby.
I also replaced all the 'lytics in the PSU, but with so-so quality caps (Xicon), as I wasn't sure I could get the unit running, and didn't want to spend too much.
Otherwise, the build quality is excellent, and the interior is clean. I have inspected the PC with a magnifier, and can find no cracks or bad solder joints.
Does anyone have any experience with fuses blowing on power down that they could share? If I can make this reliable, it will be one of the nicer pieces in my humble studio.
Thanks in advance for any suggestions. This forum is excellent, and has taught me so much.
Jim
Jim
