SSLtech
Any MIDI DIY-ers here?
« on: December 07, 2009, 08:19:40 PM »
I'm looking for a solution to an 'automation' problem... I have a few 0...5V control voltages (eight of them in fact) and a few switch closures (four of them) which I need to automate.
-Is there a general-purpose 8-in/8-out 0-5V "analog to MIDi and MIDI back to analog" board anywhere out there?
Keith
"A waist is a terrible thing to mind"
Quote from: PRR
Ah, but that was 1999; we don't party like that any more.
shabtek
Re: Any MIDI DIY-ers here?
« Reply #1 on: December 07, 2009, 08:28:10 PM »
must be MIDI? does 'sequence' need to be easily reprogrammable
"really fine players do not use stomp boxes or master volume, they match the amp to the room and turn it up to 11.  Stevie Ray, BB King, Albert King, Duane Allman, Dicky Betts, Louis Armstrong"
   -CJ
SSLtech
« Reply #2 on: December 07, 2009, 09:21:39 PM »
I'm looking to store (and later replay) the 0-5V voltages.
MIDI just seems like the most flexible thing to store, replay and -if needs be- manipulate in a computer as data/lines to 'shape' offline, or punch-in and overwrite, online.
Keith
Quote from: PRR
Joechris
« Reply #3 on: December 07, 2009, 09:53:35 PM »
Mabye Doepfer have some cards that may fit your needs. USB 64 to convert voltage to MIDI, (or pocket electronic) and MTV 16 to convert midi to voltage.
http://www.doepfer.de/home_e.htm
look under products.
two cents...
j
« Last Edit: December 07, 2009, 10:00:02 PM by Joechris »
musicians vary +/-9dB depending on mood, drugs, and line-voltage. (PRR)
shabtek
« Reply #4 on: December 07, 2009, 10:48:48 PM »
"The BS1USB is a handy little device is perfect for adding a user-definable function to your PC. For example, with a few lines of code and a little hardware, you can create a data logger that runs remotely, then uploads data to your PC each time it is reconnected. Headers provide easy access to all 8 I/O pins, power, and ground."
don't know if a uController package like this would work--it is not midi.(I've programmed 1 to spit Midi, but to eat midi is too involved for this)
http://www.parallax.com/tabid/134/List/0/CategoryID/9/Level/a/SortField/0/Default.aspx
   -CJ
kazper
« Reply #5 on: December 07, 2009, 11:02:33 PM »
Input..... 24 to be in fact
http://highlyliquid.com/midi-controllers/midi-cpu/
Output.... lots of options
http://highlyliquid.com/kits/decoder.html
So what in disneynation would you ever need to automate?
« Last Edit: December 07, 2009, 11:05:01 PM by kazper »
Intentionally left blank
Bluzzi
« Reply #6 on: December 07, 2009, 11:11:58 PM »
This handles 24 MIDI to trigger 5v logic. The code is there as well. There's more at that site.
You could mod it to give you 12 in and 12 out.
Jim
GrantB
« Reply #7 on: December 08, 2009, 03:57:28 AM »
not diy but what about motu volta?
« Reply #8 on: December 08, 2009, 04:17:54 AM »
I made a 24 midi input device a while ago, using arduino and stuff like multiplexers/demultiplexers, shift registers (for lcd), etc.
I can send you all the instructions, code if interested.
Kev
« Reply #9 on: December 08, 2009, 04:23:29 AM »
sorry if this has already been mentioned around here
http://www.ucapps.de/
look for the forum and the wiki
PCBs and parts and thingys
http://avishowtech.com/mbhp/buy.html
I have purchased but been too slack to finish a project
Kev
DIY Factory
SSLtech
« Reply #10 on: December 08, 2009, 12:17:58 PM »
Oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooh.
Thank you uncle Kev!
-You really MUST drop by more often, by the way!!!  ;D
Keith
Quote from: PRR
owel
« Reply #11 on: December 08, 2009, 12:42:36 PM »
Yes, www.ucapps.de is the source for DIY Midi projects!  Excellent stuff.
Here's my MIDI Controller (built on a cardboard, circa 2005): http://www.fivefish.net/diy/MidiLC/
Mark Burnley
« Reply #12 on: December 08, 2009, 03:22:08 PM »
Hi Keith,
Is this for your sound-to-light christmas tree controller project?
 :P
Mark
O_O tape is life O_O
SSLtech
« Reply #13 on: December 08, 2009, 08:30:24 PM »
Millennium hand and shrimp!!!
Quote from: PRR
Last post August 05, 2014, 04:39:41 AM
by ruairioflaherty
Last post March 23, 2009, 04:27:41 PM
by Yann de Kéroullas
Last post January 26, 2012, 02:45:47 PM
by gemini86
Last post June 19, 2012, 09:46:39 PM
by withnail
