e.oelberg said:
The thing is, I checked out a funk-tonstudiotechnik PSU and they are incredible clean and small and they are switchers.
Up to you, of course.
Switchers can be attractive. Switchers are nice if you are already married to a certain voltage for your main system supply and need something that's higher or lower. Switchers are handy if you go commercial, as customers find it cumbersome to change or charge more than a few batteries. Switchers can help you keep a constant output voltage for a varying input voltage. The majority of the designs I come up with in my day job have at least one switcher.
However, for DIY or small series work with qualified operators switchers have one major downside. Forget about noise for a moment. Thing is,
no switcher is 100% efficient. That sounds obvious, but for portable systems it's a big thing. A really good single-purpose switcher might have 95+ percent efficiency. This goes down for varying output currents, especially low currents. Need to support varying input voltages? Lose a few %. Want low noise? Then you have to turn your FETs on and off more slowly, and you can't use most variable-frequency schemes, and that'll cost you. A switcher that is good for audio work with battery input will likely be between 65-75% efficient, 80% if you're
really lucky.
Now think about this:
- how much extra battery capacity do you need for equivalent run time to compensate for switcher losses?
- how much batteries could you have stuffed in the space(/weight) that your switcher takes?
- if you use a switcher only for one of the voltages (Phantom would be obvious), how long would it take before the switcher has paid for itself? Consider that 5 9V batteries can supply Phantom power for 20-40 hours continuous.
Alkaline cells have a terminal voltage of 1.5-1.6V when full, 0.9V when considered empty. With a dozen AA cells a THAT15xx will keep operating fine until the batteries are empty, still driving the -10dBV inputs that that Tascam probably has without clipping.
JD 'right tool for the job' B.
