Telmar
Hi folks,
does anybody know how to modify the Gyraf 1176 for longer Attack-times ?
Whoops said:Hi Jakob,
thanks a lot for your input.
I already re-checked the circuit, and can't find anything wrong.
What I feel it's different it's the way it compresses the transients, and the punch that normally 1176 give to the drum sounds (slow attack , fast release)
I used the input with Opamp, and the output with the OEP transformer,
could that have something to do with it?
thanks
Tiago
regularjohn said:I've built a dual Rev G as well, and it sounds perfectly like an 1176. Are you sure you didn't make any mistakes in construction? Did you calibrate it properly?
Whoops said:yes it's one of the Mnats boards.
I will swap the OEP for a Lundhal ,
although I don't feel the difference is in the Tone or flavour, it's really in the compression characteristic, so I don't feel that it can relate to the output transformer.
maybe I'm wrong
