Disabling the side chain
syn
Hi
     i want to add  SPDT switch after 6al5 and before the junction of p2-p4, in order to disable the side chain action, and use 436 as line amp. The question is shall I add a resistor to gnd (6al5 out to ~1M to gnd ) or shall i leave  6al5 output floating?
Thank you.
...in order to disable the side chain action, and use 436 as line amp, when i don't need compression, but need line amp for "color"...
