seeking help for designing a small power rail splitter
pietro_moog
Florence, Italy
Hi guys!
i want to build 2 PeterC balancing board. it's just 2 5532, and i need a sort of power-supply.
i wanna stay on the chip and put this thing in a guitar pedal case, so no toroid.
i have a JLM audio 48V dc power supply, or a Boss power supply.
i think 5532s work best with +/- 15v, so i'd use the JLM power supply.
i'm a noob of electronics, so power supplies are not joke for me now.
is someone so kind to help draw a power rail splitter of some sort?
i think sort big resistor, filtering caps, diodes maybe, ad two 7x15..
but i'm not sure of anything..
thanks guys
Check with Joe Malone at jlmaudio.com.  He had a rail splitter design going for a while.  I don't know what he did with it.  It was for 24 +/- from his 48v.  I think the problem with rail splitters (if I'm not mistaken) is the potential noise generated that can make it's way into audio.
There's a couple of ways to do an easy balanced output.  You might want to pick up one of jlmaudio.com's DI boxes.  That would do the trick.  With a 48v supply that's a lot of head room!
CC
thanks
i know Jim had, i should mail him.
"There's a couple of ways to do an easy balanced output.  You might want to pick up one of jlmaudio.com's DI boxes."
i have 2 JLM fet DIs. what do you mean?  i just connect a unbalanced line at -10 in a Di (connected in a preamp) and i will find the output
balanced? i guess i could get 14db of gain..
is it a correct way to do it? will i have problems of some sort?
thanks
You will have to drop a bit of voltage from the +48 first, but you can use this TI part:
http://focus.ti.com/lit/ds/symlink/tle2426.pdf
pietro_moog said:
thanks
thanks
Joe's FET DIs and Opamp based DIs are unity gain.  They don't add any gain or take it away.  So if you put in -10 dbish signal you get that out of the DI plus added current (which makes your signal strong and durable).  If you put +4 in you get +4 out and so forth in as much as the signal does not clip the circuit.  I imagine with 48v or effectively 24 +/- should give you reasonable room before clipping.  Joe would know specifics.
The outputs from the DI are 'balanced.'  By that I mean they are balanced per AES definition and Bill Whitlock (from Jensen transformers).  The positive and negative outputs are the same impedance compared to ground.  This is where you get your noise rejection from.  Other balanced outputs (transformer or electronic) are balanced in this manner and also have an inverted polarity signal on negative (pin 3 or ring of a TRS).
My understanding is that the polarity inverted signal has nothing to do with noise rejection and more to do with maximum signal strength and a handful of other things that I can't remember right now.
Look at the top of page 3 of this white paper by Bill Whitlock - http://www.jensen-transformers.com/an/an003.pdf
Here he advocates a way to have such a balanced output if you know the manner in which your output on your unbalanced equipment is constructed.
Joe's opamp DI is kinda an adaptation of the application note (figure 9 page 12) of this http://focus.ti.com/lit/ds/symlink/opa2604.pdf and obtains the impedance balanced output much like Bill Whitlock described.
So you have a couple of ways to do this.  You could make your own thing with a balanced line sender (kinda a DI on a chip) plus a power supply, a transformer, an existing DIY product (like Joe's stuff - which I think are great and use my self), or if you know the output manner of the unit you are trying to make a balanced output from you could use Bill Whitlock's suggestion.
The nice thing about impedance balanced output is you can plug in a mono jack and not potentially damage the thing.  You have to be careful with various electronic balanced outputs depending on how it is constructed.
Good luck.
CC
