O oilcanstudios Well-known member Joined Jul 22, 2009 Messages 57 Location New Hampshire USA Jan 2, 2010 #1 Any chance u can use mnats 1176 revision j power supply to power a dual s800 eq
pietro_moog Well-known member Joined Feb 1, 2009 Messages 171 Location Florence, Italy Jan 2, 2010 #2 i think mnats' is a very good power supply. you can use it for sure, but don't ask me how, i'm noob
benlindell Well-known member Joined Feb 28, 2009 Messages 631 Location NYC Jan 2, 2010 #3 It shouldn't be a problem. Just adjust the rails for +/-15V. I've used his PSUs for several other projects no problem.
O oilcanstudios Well-known member Joined Jul 22, 2009 Messages 57 Location New Hampshire USA Jan 3, 2010 #4 thanks man is this just adjusted using trimpots?
T trancedental Well-known member Joined Jan 4, 2006 Messages 191 Location London England Jan 3, 2010 #5 R3 & R5 replaced by 5K trimpots adjusts the + / - voltage http://mnats.net/psu.html
O oilcanstudios Well-known member Joined Jul 22, 2009 Messages 57 Location New Hampshire USA Jan 3, 2010 #6 thanks!!
O outoftune Well-known member Joined Jul 14, 2007 Messages 757 Location canada Jan 3, 2010 #7 you will need to use a transformer with 15 - 0 - 15 secondaries instead of the higher value normally used for a 1176.
