AMTX
Member
At years ago, I bought a couple of tube based transmitter modules for aviation band from surplus shop.
A few days ago when I read the manuals and schematics, I notice that there is build in compressor limiter in modulator side.
What is your experts opinion, is that used circuit "good enough" and worth to keep alive or is it better to re-use parts to other projects or modify some parts of the circuit. Frequency range of the current circuit might be bit limited because modulator is intended for speech.
Currently my plan is to install two modulator sections to same chassis and modify output stage so that it's compatible with other audio equipments.
Note: Schematics are for earlier version of the modules and in modules which I have, tubes are different, but I assume that basic circuit is pretty same.
http://www.swradio.net/tech/srt_transmitter_and_modulator.pdf
http://www.swradio.net/tech/modulator_limiter_srf_su2182_a.pdf
http://www.swradio.net/tech/modulator_limiter_srf_su2182_partlist.pdf
Br,
Esa
Br,
Esa
