Twenty Log
Hey Folks,
I am designing an insert switcher and mastering console, but it seems like with a couple of "extra" configuration capabilities in the signal flow for routing, it could also be a great vinyl A/B console; accounting for playback and preview heads on a tape deck...
I understand the playback and preview concept, as that it is a delay for the needle and preview for the cutting computer in the lathe to prepare the pitch spacing in the next revolution....
I do know that the typical A/B console has duplicate equipment on the "inserts" that are A/B'ed--alternated during the carving of one song and set up on the alternate switched out set of processors in preparation for the next song...
But the disconnect in my mind, is, wouldn't the cutting computer want the preview to be the same processed signal as the processed playback just that the playback needs to be delayed.... If so, would that then be 4 sets of identical equipment (2 each, one for the preview and one for the playback both to be A/B'ed) if doing things in real-time from the master tape submitted by the client (without dubbing)?
Or... is the tape with the playback and preview dubbed (after processing) onto the preview/playback machine from a pre-mastering session using the submitted client tape
I guess my real question is what is the process with a typical signal flow for analog vinyl mastering including the signal flow through a console for playback and preview (including monitoring)?
Any thoughts?
-chris
Any thoughts?
-chris
