TheGuitarist
So i suppose the conclusion is, there will be little to no improvement vs the work involved.
What about the 003, i'd probably find someone comfortable with smd's to help me out, but can anyone suggest anything in particular.
Obvious BLA does a few mods
PSU - what could i fix with that? Obviously a better PSU that isn't switchmode (BLA uses a toroid) or something to reduce ripple, anything to improve the PSU on that front something to reduce RF interference maybe?
Signal path components, BLA say they upgrade the entire analogue stage... i suppose this means getting rid of ceramics to be replaced with films and upgrade the opamps? Not sure about the output stage (which is obviously still VERY important.)
"We're fans of Burr Brown's OPA4134, and we substitute those for the TL074 opamps used in the mic preamp and line inputs." so i guess that answers some questions.
And that converter decoupling just sounds like replacing the ceramics with higher quality caps, maybe something else? (thanks deuce for the tip!)
And as for the clock, well i'm sure its probably just much easier buying an external clock in all honesty. But if there is an easier way, someone please, chime in!
It kinda sounds like for around $50-100 in parts and maybe $100-200 in labour (complete guess on labour) one could essentially do most of what BLA does.
