thermionic
- Joined
- Jun 3, 2004
- Messages
- 1,671
Although I'm not convinced it'll give me better health, I've pretty much had enough of breathing in solder fumes. I'm not enamoured with those bench-top fans, and have decided the route to take is via a tube that clips onto the iron: http://www.farnell.com/datasheets/318002.pdf (I use a Weller WSP80)
However, the extraction pumps cost ridiculous money. My workshop is built into a room within a double garage. Seeing as I don't need to filter the air, all I need is a vacuum pump to remove the fumes - I can then dump them harmlessly into the garage, where no-one's present.
I can get an adaptor machined so I can fit the Weller tube to the valve on the pump. The question is, what kind of pump should I go for? How would I calculate the required air flow? Could I get away with something like an aquarium pump?
I'm prepared to buy a cheaper pump than a Weller and save the bother of DIY, but no-one seems to make them.... I've found Metcal and Xytronic, but they're no cheaper.
Many thanks in advance.
Justin
Justin
