Whoops
Re: [BUILD] 1108 DIY project and PCB layout
« Reply #220 on: May 12, 2020, 06:00:01 PM »
Neve 1290 (the preamp circuit on the 1073) uses +24v.
And there's a lot of modules based on this preamp  for the 500 series .
Check the schematics for those and see how they implemented the +16v to +24v
https://groupdiy.com/index.php?topic=41147.0
https://groupdiy.com/index.php?topic=33492.0
Saying this, there's much more simple projects to pursue for someone with your experience so chasing this one for the 500 series might be too much.
There's already a lot of amazing preamps for the 500 series, with pcbs already made and the project well documented
« Reply #221 on: May 12, 2020, 06:13:57 PM »
Thank a lot for those. I'll study them
I hear you man. I built an 1176 rev D a few years ago and love using it as a pre amp so I'm pretty set on the 1108 so I'll keep at it for some time.
Another question: My rack (Radial workhourse 8) has a TRS omni port on the back for each channel that corresponds to pin 7 and 9. Would it be possible to send 24 volts through the omni port via another power supply or is this insane?
« Reply #222 on: May 12, 2020, 10:21:43 PM »
So I studies the don classics nv73 converter circuit from the schematic. Given my limited knowledge  it looks exactly like what I need but am unsure after playing around in lt spice (for the first time). I would be willing to pay someone to help me figure this out. Hopefully this is an appropriate post... please remove if not.
Whoops
« Reply #223 on: May 13, 2020, 12:47:08 AM »
as this thread is for another 1108 project, not the one you're after, I think you will be better in doing a new thread for a 1108 project in the 500 series format, to gather some help and have the relevant info compiled there
« Reply #224 on: May 13, 2020, 01:03:57 AM »
Ahh, will do. Thank you much, for your responses.
louder
« Reply #225 on: June 28, 2020, 07:35:18 AM »
Hello
Long time no see.
After reading the whole thread one doubt... J309 it's out of production... Beside eBay where can I get some?
Best regards
TwentyTrees
« Reply #226 on: June 28, 2020, 07:59:26 AM »
Cricklewood Electronics in London seems to have them in stock:
https://www.cricklewoodelectronics.com/J309.html
Hello
Long time no see.
Best regards
louder
« Reply #227 on: June 28, 2020, 09:22:54 AM »
Regards
Whoops
« Reply #228 on: June 28, 2020, 03:47:45 PM »
Hello
Long time no see.
Best regards
Mouser has J309 in stock:
https://www.mouser.com/ProductDetail/InterFET/J309?qs=OxRSArmBDfxFLq%252BlAKFMwA%3D%3D
Probably any of this would work well also as a replacement:
2SK170
LSK170
2SK370
2SK117
2SK369
2N5457
2N5486
BF862
louder
« Reply #229 on: June 28, 2020, 06:15:26 PM »
Thank you.
Obrigado
JerryPbury
« Reply #230 on: January 04, 2021, 01:51:23 PM »
Wouldn’t this work, connection to 5, E and ground?
JerryPbury
« Reply #231 on: January 04, 2021, 01:58:02 PM »
I also have a few UTC A-10’s to try this:
Title: Re: UREI 1008 Mic Preamp Schematic
Post by: Bill Wilson on May 13, 2010, 01:14:51 PM
For the input transformer a UTC A-10 would do very nicely. It has a winding ratio of 1 to 10 & has the necessary taps on the primary. The secondary impedance is 50k ohms & will take +15dbm before the core saturates. The freq response is down only 1 db @ 30cps & .5db @ 20kcps,
(oop's hertz), forgive me but I cut my teeth on tubes back in 52.
The A-10 will work for the 1008 & 1108 as they are to single grid & single FET; it will not work for 1016 as it is a balanced circuit configuration & requires a split primary. A UTC HA-114 will work well as the output xfmr. for the 1016, it is 30k ohms split primary w multiple secondaries covering all the pro output impedances & will handle +23dbm. It is perfect for a 12AY7/6072 in push pull. Freq. response -1db 30hz to 40khz. Input trafo. for 1016 would be a UTC A-12, it has split windings on the secondary for push pull.
Have not take the time to look @ 1108 in detail so cannot give you anything but a guess on the output trafo's impedance but could be around 600 ohms.
I can guarantee the frequency response of the A-10 as I used them in a 6 input 3 channel mike muxer in 64; when I was doing on location mastering for a couple of small rcord co's.
Hope this helps.
Bill W.
P.S.: the dbm figures on the transformers are for the 600 ohm impedance.
dmp
« Reply #232 on: January 04, 2021, 03:48:17 PM »
Gain control - I used 1Meg audio pot in place of the LDR for level control. This worked great. If you are controlling them further away with a fader you might want a LDR, but in a single unit it's not necessary. This gives you control from off to max. You could easily build a stepped switch instead of a continuous pot if that were preferred.
The gain control on these is a two position switch that changes the amount of negative feedback. I've always used them on high and don't the switch is even necessary. You could probably make a stepped switch to change the gain in more steps, but I don't think you can get much more gain out of them than the 'hi' setting of the design.
And I put a pad on the front ahead of the input transformer.
These sound great. I used UTC O-1 / O-2 but any 1:10 mic transformer will work
Last post April 24, 2006, 03:10:45 PM
by CJ
Last post July 16, 2008, 11:15:49 PM
by AJMAC
Last post January 18, 2010, 04:00:37 PM
by oilcanstudios
Last post August 27, 2013, 06:22:09 PM
by j.frad
