briomusic
you are aware that you should have one 2N4910 and one 2N4898 each on the out amp, right? how about going to the output level pcb, are you getting signal at S3-1?
echotodd said:I even tried disconnecting the screws I used to mount them to the PCB and I'm still showing nothing at the unbal. output.
echotodd said:Always the obvious. The issue was not insulators my dear friends. It turns out the lock washers on the kepps nuts I was using overshot the pads. Now my only issue is that I am slamming the hell out of my input. My guess is that I have the hold wired wrong. To be honest, I'm embarrassed.
oceres said:Hi,
Would it be possible to use Ed Anderson's EA-1166 output transformer in TG1 build?
http://hairballaudio.com/docs/1166/1166.pdf
