Hi!
I've spent my spare hours over the past few days tinkering with a couple of Neumann/Gefell/VEB UM57 mics, along with a CMV563/551 and an adapter (courtesy of Thiersch) to connect to Gefell UM70 and M71 capsules. I've been trying out some of the published modifications on the web - more of that shortly - but I wanted to note down a few of the differences and similarities whilst they're fresh in my head. I guess there is nothing earth shattering here and these mics are documented elsewhere. But Le bon Dieu est dans le detail*, und so weiter.**
Firstly, the two UM57s...
Both mics appeared to be extremely original when I first received them. Mic on the left is VEB badged and serial number in the 4900s, on the right is Neumann badged, and in the 4090s. The VEB has a circuit board and a different layout from the point-to-point wired earlier Neumann. On the P2P layout, the output cap is on the reverse side of the board. The orange poly cap is a replacement (by me) for a faulty electro. The circuit board on the VEB mic is marked both 563 and 57, suggesting it was used for both.
The VEB came with an RFT tube that was marked as 'M' grade, presumably tested and selected in the factory. I haven't seen this extra red stamp before. This seems to be as quiet as the NOS Tele tube I fitted to replace the standard RFT in the 'Neumann'.
In fact the mics sound extremely similar in this configuration, despite the differences in layout and components. To my ears the difference between the old (but good) electro cap and the new poly cap is not obvious.
Getting late here and whiskey calls. I'm going to post and save this - more about testing some of the mods and capsules in the morning...
z50
* Gustave Flaubert, allegedly.
** move along, nothing to see here, etc
z50
