"Stock" PI-Filter Choke Construction
thermionic
I've found a tame coil winder near me who's reasonably priced. I have a few small signal valve projects coming up, so I thought I might see about getting some 'stock' chokes wound to use in pi-network PSUs. The idea being that I can employ the chokes on a variety of projects, be it preamp, EQ or compressor etc.
The winder makes everything to order. He doesn't really get involved in the design process. He's got a well equipped factory with CNC gear and makes custom designs for respected audio OEMs. Can anyone give me a starting point for the kind of lams I should look for? I'm thinking something around 10-20 Henries with 10-20mA of handling @ <200R DC resistance - would this constitute a good "stock" PSU choke in your book?
Many thanks in advance.
Justin
silicon steel is used in most chokes, 0.014
coil construction for a pwr supply choke is simply a start and a finish on one bobbin,
no fancy winding required, can be random wound
i forget which end gets the B+,
really does not matter as both ends have about the same voltage on them
what kind of projects are you going to power?
Justin
For small signal work that value fits the bill for a typical PS choke.  I don't think they're as critical in voltage amps as they are in big power amps though Langevin and WE have used them on some 1 watter 6v6 line amp circuits.
They're handy for dropping excess voltage off an overrated PT - ~50V.
For what you can buy them from Hammond for - 18.00 -I'd vote for seeing if your winder can wind you some nice high inductance plate chokes instead  ;)
holy crap, i called this utc a traid,
too many threads at once, i guess,  :p ;D :D
http://www.groupdiy.com/index.php?topic=36493.0
oh yeah, the most important thing,
you need to gap the core with some kraft paper,
Why do you need 10+H with under 4V DC drop?
That inductance suggests >5K audio impedance. At 10-20mA you must be expecting 50-100V somehow. And probably several hundred? So starting from 200V, what's the difference if you get 196V or say 180V?
Also a 10K AC impedance with a 200r DC impedance suggests a Q like 50, which is mighty high for a simple iron-core coil. It may not be possible with a reasonable lump of silicon steel carrying DC. It won't be affordable in Permaloy, even before you bulk-up to handle the DC.
If you can get an AC/DC impedance ratio near 10, you are doing a lot better than an R-C filter, yet with a practical choke.
If you can custom-wind, wind your PT HV up 10%-20% from what you need. Then you can take that 10%-20% back down in higher-resistance chokery. While this adds 5%-10% to PT cost, it may save a bunch in choke cost, or make an impossible design trivial.
BTW: the larger stock "Fender replacement" guitar amp chokes will carry 20mA and are nearly 10H at under 1K DCR. Unless your guy just loves to throw wire at a loss, he probably can't match the cost of low-pay imports, even with transport and dealer markup.
A variety of small signal projects, ranging from mics to compressors
I didn’t realise Hammond sold them so cheaply. Will check them out. I looked into Plate Chokes. I’m sure he could make them. However, they’re more tricky to get right than PSU chokes. Secondly, it’s difficult to have a ‘stock’ plate choke as they have to suit the Rp of the tube being used.
I don’t. Not sure what made me think that. Your logic makes sense. I can always specify a higher secondary voltage.
Thanks to all of you.
Justin
