Phantom trouble
MikkelM
Denmark
Hi there
I have just used the Phantom power diagram from Bo Hansen.
I only get ca. 20V out on Darlington pin3!!!
measument on the Darlington pins, with the Darlington not inserted.
Pin 1 and 2: 22.7
Is the Darling fried??
THanks
Mikkel Meyer
Whoha! Big schematic :green:
If you don't have 'bout 51v across the zener, I'd look into the voltage doubler..
When transistor die they nearly always die 100%...
Ahrhjaa Gaaa!!! I have done some completely stupid on my PCB.....
Fuck simple circuts, because they are simple!!
I'm not quite sure what you mean, Mikkel :?:
If you allready have rectified the AC to DC you can't use the voltage doubler part. The doubling is 'happening' in the rectification, so to speak.
I'd say you either follow the circuit bit by bit OR use a standard 50VAC trannie and rectification. Makes sense?
Yes! I see.. I have pulled it all away, have been sitting with this small thing too long.. It only outputs in silly panic questions... Sorryyyyy!
