R17 2k7/6k8 -again how do I determine the correct value?Different schematics have different values. This is the q setting resistor for the mid inductor. I used 6k8.
Any idea when the Ed Anderson input transformer will be ready?
u1K63 wima caps
cap are you guys using for C50?
Can someone explain what CW W CCW means for the smaller potentiometer wiring? I am assuming it means clockwise w? counter clock wise, but how do I know what is what on the PRV6?
So is the bias setup the same as the pre's ?
RV4/5 -what is the alignment procedure for these trimmers? is it similar to the 'symmectrical clipping' process on the 1290 preamp? Exactly.
Started by lolo-m « 1 2 ... 10 11 » Dynamic Processors
Started by peter purpose « 1 2 3 4 » The Lab
Started by number2 The Lab
Started by TheGuitarist Filters/Equalizers
