12volts
Re: EQN build thread
« Reply #220 on: September 06, 2010, 04:36:05 PM »
Peter, is this right for the switches?
I stuck resistor leads in to show the placements.
This is for the top 2 switches.
Dan, summat else.
On top of your pin location problems ...... If you look on the photo, you haven't filed down the PCB
'pips' left over from routing. The metalwork sits flush on this edge. The 'pips' have to be removed before
assembly .......
Frank
« Reply #221 on: September 06, 2010, 04:52:05 PM »
Frank... he's obviously a muso in a hurry.
http://www.lazpro.com
I reserve the right to not sell to idiots
12volts
« Reply #222 on: September 06, 2010, 05:01:40 PM »
I have a soft spot for musos. Because of them I drink.
Frank
« Reply #223 on: September 06, 2010, 05:28:11 PM »
Frank.... That's why I got out of the studio business.... I still drink though..!!
dandeurloo
« Reply #224 on: September 06, 2010, 06:46:38 PM »
Thanks for the compliments guys.  I do make my living from making music and working with musicians... not circuits as I am sure you can tell.    Because of that I do have plans for this wonderful project as soon as I can get it wrapped up.
Frank I do have plans for a little file time once I go to the shop again.  Sharpe eye!
PROFESSIONAL CHASSIS AND FRONT PANELS FOR DIY PROJECTS: WWW.COLLECTIVECASES.COM
Dan Deurloo
www.collectivecases.com
www.risendrums.com
« Reply #225 on: September 06, 2010, 07:32:40 PM »
Dan... don't try to seduce Frank to into giving you the answer you lazy twunt.... read something.!!
dandeurloo
« Reply #226 on: September 06, 2010, 07:33:46 PM »
Wow Peter...
Dan Deurloo
www.risendrums.com
zayance
« Reply #227 on: September 06, 2010, 07:35:00 PM »
Sorry Mr Peter for helping out  ;D Here is the instructions for the Grayhill if you still need it. And IIRC, when watching the switch from the front with pins flat on the desk, you have to put a pin at 12o' clock, and one at 6 if you want it to switch 6 position etc...Seeing your pictures you just got the switch at 90°, if you check at the back you'll see the numbers according to the positions. Correct me if i'm wrong. And just have to make sure the point 1 of the instructions, if this can help?
« Last Edit: September 06, 2010, 08:12:09 PM by zayance »
dandeurloo
« Reply #228 on: September 06, 2010, 07:42:20 PM »
Thank you good Sir!
Dan Deurloo
www.risendrums.com
dandeurloo
« Reply #229 on: September 07, 2010, 11:30:05 AM »
I am 99% sure I got the switches correct thanks to some info from zayance!  So, if anyone else gets hung up on the same thing I did here are a few things.
1. 12:00 on the switches is with the eq laying down pins against your work surface.  Not in the standing up position that it will be in the 500 rack.
2. With this as your starting point the info on page 6 makes sense!
3.  The other thing I kept getting hung up on was the orientation of the flat portion of the shaft.   In this application it doesn't matter other then in making sure you have it start opposite position 2 on the switch.  I was thinking that the screw of the knob would screw into this portion of the shaft like they generally do, but that is not the case!  Just get the positions to work correctly then line up the knob so it points properly on the faceplate.  Not the flat part of the shaft.
Hopefully that info will help anyone else from getting hung up on the switches.
Dan Deurloo
www.risendrums.com
« Reply #230 on: September 08, 2010, 07:16:46 PM »
Been Stuck for a couple of days. Fired it up. Power seems to be getting where it needs to and measures correctly but i'm not passing any signal with the eq in or out. Can someone give me a clue on where to start on this. I have resoldered every point on the board.
dandeurloo
« Reply #231 on: September 08, 2010, 10:27:39 PM »
got any pics?  Is the output tranny wired correctly?
http://www.groupdiy.com/index.php?topic=38884.0
Dan Deurloo
www.risendrums.com
« Reply #232 on: September 08, 2010, 10:42:51 PM »
I will check again tomorrow but I'm almost 100% sure it is.
briomusic
« Reply #233 on: September 09, 2010, 04:36:17 AM »
@technut: have you tried toneprobing or scoping around the circuit to see how far the signal gets?
in my case it was 'broken' right at the input transformer and the source (dodgily balanced output of behringer headphone amp) ended up being at fault.
good testing points are R7 (right before the eq section) and C48 (right before the output amp).
« Reply #234 on: September 09, 2010, 09:00:08 AM »
Any overnight joy technut?
« Reply #235 on: September 09, 2010, 10:40:59 AM »
Just got to work. Output transformer is wired correctly. Will probe during lunchbreak.
« Reply #236 on: September 09, 2010, 04:46:57 PM »
Ok i tested at r7 and c48. both are very faint but the same level at both. Maybe its the input tx. I have the right wires connected to the proper places on the pcb. Maybe i dont have the right stuff strapped together on it. Heres how I have it wired. 2 to 4,3 to 5,3 to 4,7 to 8 and 9 to 10.
« Reply #237 on: September 09, 2010, 06:45:29 PM »
OOOO NO...... !!
Have another look at that schem..... 3-4 as a starting point.
« Last Edit: September 09, 2010, 06:49:16 PM by peter purpose »
« Reply #238 on: September 09, 2010, 06:50:05 PM »
Ok I will. Thanks Peter!
« Reply #239 on: September 09, 2010, 09:32:21 PM »
All fixed!!!!! Just need to calibrate. Thanks again!
Last post November 03, 2010, 01:51:16 PM
by pH
Last post May 04, 2011, 12:44:32 PM
by peter purpose
Last post January 23, 2012, 08:48:55 AM
by peter purpose
Last post October 24, 2012, 01:26:04 AM
by haima
