dandeurloo
Re: EQN build thread
« Reply #520 on: October 26, 2012, 01:20:49 AM »
yep, super easy.
PROFESSIONAL CHASSIS AND FRONT PANELS FOR DIY PROJECTS: WWW.COLLECTIVECASES.COM
Dan Deurloo
www.collectivecases.com
www.risendrums.com
jrowell
« Reply #521 on: October 28, 2012, 03:17:16 AM »
Thanks so much Dan for your confirmation and assistance to other members.
I am happy that it seems to be working so well.
Thanks again guys,
James Rowell
Sound Service Electronics
canidoit
« Reply #522 on: November 01, 2012, 05:49:42 PM »
yep, super easy.
So Dan, are you saying jrowell's mod fixed your low end issue with your build??
iva dunit formerly known as canidoit
dandeurloo
« Reply #523 on: November 01, 2012, 10:52:10 PM »
yes
Dan Deurloo
www.risendrums.com
jrowell
« Reply #524 on: November 11, 2012, 02:35:11 PM »
Hi Guys,
We should probably stop calling it a mod.
That implies we are changing something to overcome an inherent deficiency.
This is a missing connection fix. We are putting in something that should be there and is on originals.
Very complex to put all this in a 500 format and I have worked in lots of big console modules that have a lot of cut traces and forests of jumpers from the factory.
Even the big N.
Let's call it 'the James fix'
Cheers guys,
James  Rowell
canidoit
« Reply #525 on: November 24, 2012, 07:06:56 AM »
The mod fixed!  Thanks James great catch.
Dan, did you have to re-calibrate your unit??
When you calibrated your unit originally, did you do the normal calibration process that Peter mentioned prior to doing the mod. I wanna know if you followed Peter's original calibration, cause I did, and if you did not have to re-calibrate your unit after doing the mod, then I would not have to either : )
Thanks mate
dandeurloo
« Reply #526 on: November 24, 2012, 10:51:05 AM »
No I didn't re cal it.  It really is a 10 min fix.  It takes more time to take the knobs off then anything else.
Dan Deurloo
www.risendrums.com
« Reply #527 on: December 14, 2012, 11:29:29 AM »
Am missing 1-2 BC184 for TR1 and TR2. has anyone replaced them successfully with modern components? Will a BC547/549/550C work there?
Have two of those, first one complete BC184. If I want to use them in a pair, will it make a difference that one might have a replacement tranny?
« Reply #528 on: December 16, 2012, 04:30:24 PM »
Man, this one is a pretty fun build!
Quick question, on Mnats notes, he wired the screen to the carnhill screw.
I am not using a bracket, instead, mounting directly on the PCB (2 screws provided). The screw socket tests continuity to the goldfinger, so does the "SCREEN" PCB hole. The screws all measure continuity. However, soldering a piece of hardwire to the  pin and then stick it under the screw I can't get continuity.
Am I being daft (eg you need to solder to the screw as well?) or should I just go the old way (pin 6 to "screen" PCB point?)
jrowel: "It depends on how much is wrong with the module. There is something wrong with almost all of them. "
ruairioflaherty: "Mr. EMI's children have bigger problems than some solder monkeys"
« Reply #529 on: December 22, 2012, 05:17:36 PM »
Hey guys just trying to understand this build a bit more, other than just sticking some solder blobs on a pcb:
- the 4.7M resistors are only there to avoid popping when swapping the resistors?
- The 620ohm resistor on a jumper, is this to emulate a o/p load?
- the jumper will allow 24v through for supply, but what happens where there's the 2 voltages present?
- any good source places for information on this kind of equalizer topology? I'm really not following how the whole Q (resistor divider before the amp) affects the signal
Tell me to shut up if I'm being silly. I did get most of the power section from the discussions about the TDK lambda on the old thread (using it the other way around).
Can you say that the input is a passive design with Class A o/p?
Tell me to shut up if I'm being to annoying. :)
:Guinness:
« Reply #530 on: December 28, 2012, 11:39:47 PM »
Shut up.... you're being really forgen annoying.
1 As far as I know... yes.
2 Yes
3 You'll either add the components for +&- 16v, or leave them out for 24v. Jumping for 24v when using dc-dc converter will result in death.
4 NFI
http://www.lazpro.com
I reserve the right to not sell to idiots
« Reply #531 on: December 29, 2012, 02:05:24 PM »
This explains why I had to put the kits airing outside :P
Sorry for the hijack! back on thread... carry on
dandeurloo
« Reply #532 on: December 29, 2012, 02:19:10 PM »
Where did you get your knobs?  I wouldn't mind getting enough for my pair.
Dan Deurloo
www.risendrums.com
« Reply #533 on: December 29, 2012, 03:24:59 PM »
those are something that Peter made for his stuff he said he wasn't selling them as they were for the finished units he was selling.
Not sure if it's still the case.
I'm using the skirted Kilo for the frequency and the normal Kilo with a line for the boost/cut. Pretty sweet! :)
« Reply #534 on: December 31, 2012, 02:29:09 PM »
Finished mine. Gorgeous! will callibrate it when I finish the second unit in 2013 :)
Happy new year y'all!
« Reply #535 on: January 01, 2013, 12:08:48 PM »
Finished my second one! Calibrated both to the level and applied throw freq mod. Sound amazing!
canidoit
« Reply #536 on: January 02, 2013, 02:36:43 AM »
What is the throw frequency mod?
« Reply #537 on: January 02, 2013, 05:43:11 AM »
LOL
Lesson #7 - When typing from iPad, make sure to read what it will send over when you click submit...   :-[
I meant to say the Low Frequency mod.
« Reply #538 on: January 02, 2013, 05:24:12 PM »
the James Fix? :)
« Reply #539 on: January 06, 2013, 04:04:07 PM »
Finished 2 units. Ran them phase opposite and they are super tight! they begin to drift at 7kHz.
Hopefully will put them against n$$e reissues some time soon.
Pete made these too easy to build! :P
Question: my 51x is not running the 24v rail atm.
I have populated the parts for VPR 500 and am running of 16v no problems. Jumper is not in
When I finish the PSU supply, do I have to saw off the tab with the above configuration?
And - if needed in future - is taking out the TDK lambda and putting a jumper enough to go 51x 24v or do I need to remove further components?
Last post November 03, 2010, 01:51:16 PM
by pH
Last post May 04, 2011, 12:44:32 PM
by peter purpose
Last post January 23, 2012, 08:48:55 AM
by peter purpose
Last post October 24, 2012, 01:26:04 AM
by haima
