I'm looking to rig up a Johnson Trailblazer with a 'permanent' internal piezo pickup installation, and would like some advice...
This is the guitar (sounds very sweet, if a little quiet...) www.jklutherie.com/johnson-travelguitarwgigbaginstruments.aspx
I have this kind of sensor in 35mm, 27mm and 20mm:
http://cgi.ebay.com.au/5-35mm-Piezo-Elements-Sounder-Sensor-Trigger-Drum-Disc_W0QQitemZ120526869145QQcmdZViewItemQQptZUK_BOI_Electrical_Components_Supplies_ET?hash=item1c0ff61299
The plan is to use a 35mm about an inch from the bridge on the bass side (found what seems to be a sweet spot by 'listening' with fingertips P ), a 27mm right up against the bridge in the middle, and a 20mm on the underside of the bridge itself on the treble side. The idea being to pick up as much tone as possible by not just having a single sensor which could miss a vibrational mode of the guitar top by being placed on a node...
Questions:
1) Should the sensors be glued with the ceramic side in contact with the wood?
2) Can the three sensors just be hooked in parallel straight into a single buffer, or should they be buffered first, then mixed?
Any other comments or suggestions would be welcome
Questions:
