Holger
Holger's Green Line cont'd (GSSL)/Pics
« on: February 18, 2010, 03:47:27 PM »
Just finished a nice looking GSSL with an old Weston meter.
It has some modifications like Turbo board. I left out the 0.1µF in the I/O section per Kingston's suggestion. I replaced the 5532/5534 with OP604/2604. I am also testing some output transformers, starting with old Altecs here.
[silent:arts]
Re: Holger's Green Line cnt'd (GSSL)/Pics
« Reply #1 on: February 18, 2010, 03:51:50 PM »
your compressor rack must be huge now ;D ;D ;D
don't tell me you produce anything with them, I know you have a day job, and I know how much time DIY takes ::)
your output is incredible :o :o :o
and always this clean work, and those nice looking designs 8) 8) 8)
great work, congrats :)
ultra-alex
« Reply #2 on: February 18, 2010, 04:59:43 PM »
looks great! i really like that style. congrats.
cheers, alex
livingnote
Re: Holger's Green Line cont'd (GSSL)/Pics
« Reply #3 on: February 18, 2010, 10:49:52 PM »
We appear to be having a lot of fun tormenting that same old box, eh?
Nice job. I love that meter.
Quote from: emrr
F-in' hook some Sh*t up and see if it catches on fire
Living Note Studio
Kingston
« Reply #4 on: February 19, 2010, 04:10:12 AM »
Since you're out to do opamp swaps, the I/O section is the nice first touch, but there's more you might want to experiment with.
Try OPA404 as the quad opamp. Remember there's one on the turbo board as well. While a modern opamp in the I/O section will clean up t hings a lot, OPA404 actually changes compression characteristics. The TL074 is "too slow and distorted" for the sharp rectified audio discontinuations. While it results in the familiar SSL punch sound, it's obviously distorting in many ways, most obvious on fast attacks and stereo imaging. OPA404 takes the compression more into the mastering area.
I went further and tested OPA604 as the VCA driver's as well. Surprising compression characteristic change, again obvious on fast attacks and imaging. Some would say it makes no difference just how crappy opamp drives the control signal, but don't take this from me, and hear it yourself. It's not subtle.
Kingston
« Reply #5 on: February 19, 2010, 04:15:24 AM »
I see you are using 100nF as the VCA driver opamp feedback cap. Whoops! Did you at least try 100pF (or even 47pF) first?
I know the 100nF is a commonly accepted recommendation, but damn, it sounds like sh*te! It completely kills the accuracy of the control signal, and this is no subtle difference. You can't have fast accurate attack with 100nF at all and even release will become "restless".
I seem to recall you have more than one GSSL built. Compare them side by side. You will be surprised.
« Last Edit: February 19, 2010, 04:21:27 AM by Kingston »
Holger
« Reply #6 on: February 19, 2010, 05:37:00 AM »
Kingston, thanks for the suggestions. I will try them.
Holger
« Reply #7 on: February 20, 2010, 08:56:49 AM »
Little bit off topic, here it is
livingnote
« Reply #8 on: February 20, 2010, 09:29:45 AM »
Look out America, the Germans are at it again  ;D
Quote from: emrr
Living Note Studio
drpat
« Reply #9 on: February 20, 2010, 08:13:37 PM »
« Last Edit: September 18, 2010, 03:06:18 AM by drpat »
I use the LA2a on very hot signals like lead vocal.
livingnote
« Reply #10 on: February 20, 2010, 09:44:01 PM »
Wax on...mouth off :)
...for a while there as a kid there was nothing I wished for more
than a phial of ooze. Or at least a job at TGRI.
Man, that was back when we lived in Davis. I really miss the place...
Respect for your rack of course, but I didn't mean it quite that way -
I was thinking more like I might warn the Pentagon they weren't
thorough enough in '45 when it came to Das Boot. Ten more
years of ol' Holger and it'll be Hemp For Victory all over again...
« Last Edit: February 20, 2010, 10:19:15 PM by livingnote »
Quote from: emrr
Living Note Studio
Snatchman
« Reply #11 on: February 20, 2010, 10:09:21 PM »
Amazing...! :o
Thanks for your time and ears!
mingus
« Reply #12 on: April 17, 2011, 01:38:24 PM »
hmf! and here I´m still sitting 1 year later and wondering how to get the psu wired up for 230V.
Instant rookie feel.
Great job there!
m
mylesgm
« Reply #13 on: April 17, 2011, 10:42:46 PM »
Want to go through what the rack of gear actually is?  Those builds look great!
Check my work at www.mylesmumford.com
pietro_moog
« Reply #14 on: April 18, 2011, 01:35:10 PM »
hi Holger.
how do you make your panels?
you paint them yourself and then Schaeffer?
« Last Edit: April 18, 2011, 02:40:24 PM by pietro_moog »
Holger
« Reply #15 on: April 18, 2011, 02:18:45 PM »
Usually I'd let them paint at a local paint store, the engraving is done by Schaeffer or Frank/NRGRecording.
sonicwarrior
« Reply #16 on: August 15, 2011, 02:12:06 PM »
Is that the 100n between the opamp and the VCA?
The other two 100n look like they are just for decoupling (between ground and +15V or -15V).
Last post August 18, 2004, 09:42:38 AM
by SSLtech
Last post October 20, 2005, 04:17:43 PM
by Christian
Last post August 10, 2011, 10:10:47 PM
by JimiH
Last post June 12, 2013, 07:05:12 PM
by desol
