been working on git amps since 1970, never seen an amp with the .047/600 fail,
don't know if it is because they just see 60 hz or because the only see 120 V-ac, whatever the reason, never heard of anybody getting shocked by that cap shorting to the chassis, in fact. that is probably the only part i have not replaced in an amp due to failure,
how many old Fender amps are still out there with that cap? or in these amps>
Marshall, Ampeg, Peavey, Acoustic, Line 6, Soldano, Trainwreck, Silvertone, Splawn, Kustom, Egnater, Orange, Schaller, Crate, Sunn, Magnatone, Randall, Tradesman, Vox, Hartke, Mesa, Traynor, Musicaman, Carvin, Zenith, Motorola, Ford, Chevy, Chrysler, Hiwatt, Laney, B-52, Bogner, Red Bear, Alamo, GK, Gibson, EMG, Blackstar, Behringer (ugh), Krank(RIP Dimebag), Rolland, SWR, Tech 21, Fishman, Tube King, Epiphone, Phil Jones, Leilani, Nu-Amp, Hughes and Kettner, Kendrick,
take it out if it makes you feel better, but don;t stress too much over it,
would UL pass an amp if this cap was unsafe?
if anybody has a story of that cap causing trouble i would love to hear about it,
that cap can be useful when gigging some places have weird power and using the ground switch can quiet down an amp, three prong plugs are great if you don't clip the 3rd prong with dikes because you forgot the adapter and the house you play is old,
if that cap does short out, it will either self destruct or blow the amps fuse of connected from hot to chassis and the chassis is grounded, or it shorts from hot to chassis on an ungrounded amp you will only die of you touch something that is grounded, what would that be? a toaster? a hot water pipe? not too many hot water popes in the jam ran, unless your playing the Voyeur here in town, you want to see an out of code rats nest check out the tanatula room in the back next time you are in OlyWa, can't say i like the tickle i get when i do get that 56K resistor between me and the mic or the other git player,
not the most conservative answer, but then again, i like free climbing and white water kayaking, Jaywalking, dipping transformers indoors during winter time, having unprotected sex with multiple partners,
