Mike Cleaver
Re: Restauration of STUDER 169 console
« Reply #20 on: April 29, 2010, 08:43:35 PM »
Beautiful job!
Your work looks excellent.
I love old Studer stuff, used to do a lot of work on their tape machines and cd players.
roginator
« Reply #21 on: April 30, 2010, 04:29:07 AM »
i like the extender
can you give me a hint where to get the connectors ?
thanks
arne
in your console... if you use only 2 bus!!!!! you have 4 spare connectors in it that you will never use!!!for quad !!!
so 4 connectors are there
......latter if you want you can return them to console!!!!!!!
Brain is CV controlled device!!!!!! so we all are analog sequenced machines!!!! " ROBOTS "
smallbutfine
« Reply #22 on: April 30, 2010, 05:39:38 AM »
Excellent how-to with excellent photos!
I did not realize there is a simple 'de-magnetizing' procedure for transformers!
Is it really a hearable improvement or do you do this just to be sure that nothing is sub-optimal?
"In the past we suffered from crimes, today we suffer from laws."
Tacitus
www.audiomh.de
roginator
« Reply #23 on: May 08, 2010, 01:54:12 PM »
yes .. in 2 of cca 26 transformators i heard a big difference in bass !!!!!
roginator
« Reply #24 on: May 08, 2010, 01:54:46 PM »
Calibration of Studer was easy ... only problem was calibration of limiter
1. calibrate DC - DC converter
2. Calibration of Input modules was very easy to set 10db on fader amp..(with multiturn trimpots its very easy heh )
3. calibration of outputs x4 ..2 for stereo out, 2 for sends... THD calibration, easy by the book
4. CALIBRATION OF LIMITER WAS PAIN!!!!
5.calibration of talkback module and monitor module went great BY THE BOOK!!
6. still have to calibrate meter bridge!!!
ok lets get back to limiter calibration.... problem of calibration was to get identical levels in master modules..
HERE IS WHAT WAS A PROBLEM .... there are few zener diodes 7,5v and few 1N4448 diodes..
CHANGE THEM ALL and then do calibration of limiters!!!
they were leaking and voltages were not correct .. old diodes out , new in!!!!!!
hope that will help few of you guys who do calibration of your studer 169 consoles!!!!
isophase
« Reply #25 on: May 08, 2010, 02:29:45 PM »
Wow
excellent, thank you for sharing
"we'll fix it in the shrinkwrap" fz
« Reply #26 on: May 21, 2010, 01:21:52 PM »
Does anyone know a source for the knob colored caps?
« Last Edit: May 21, 2010, 01:27:45 PM by mono-poly »
« Reply #27 on: May 21, 2010, 01:55:53 PM »
I think i found them.
ELMA makes them now let's see if i can buy some.
radiance
« Reply #28 on: May 22, 2010, 04:03:57 AM »
what colors (size's) do you need mono?
Might have some left ...
"Knowing that you are dreaming, however, does not automatically guarantee full rationality.
Then again, being awake doesn't ensure good thinking, either." -  Lynne Levitan
livingnote
« Reply #29 on: May 22, 2010, 04:11:22 AM »
Yeah haaa so cool!
Quote from: emrr
F-in' hook some Sh*t up and see if it catches on fire
Living Note Studio
roginator
« Reply #30 on: May 31, 2010, 07:22:44 AM »
OK one note!!!!
I realized that all faders are not same in my console
and that took me cca 3 inspections of all modules to realize all mess!!!!
1. all faders have same part nr in studer service manula 1.169.550.00 BUT they are not all same!!!
2. in my desk i have 4 different values of faders!!
3. having that mixed I didnot like how my 169 behave!
so I service manual is pointing to only 2 values of faders in 169
2Kohm in input channel (mono) and 5Kohm in master... after a resears i realized!!!!
studer marked faders with their code (i think so heh )
and
markings on faders:
926 = 2K
902 = 3K
944 = 5k
104 = 10k
roginator
« Reply #31 on: May 31, 2010, 07:23:35 AM »
IM LOOKING FOR 2x 926 2K studer faders for 169
1954U1
« Reply #32 on: September 29, 2012, 08:18:40 AM »
I'd add to this really useful topic some things I've done in the last years:
1] cleaning pushbuttons
All you need is a syringe and some contact cleaner fluid.
There are small linear openings at the rear top of the switches.
2] Transformers repair
I've had a faulty line transformer in an input module:
the primary's connections [6 and 8 are the interesting ones in input module] to the pins
were lost.
Repairing them is really easy, all you need is a little tip on your iron,
positioning the transformers so the solder will flow, thanks to gravity law, towards the wire, and a firm hand.
[as you can see, I've also cut/melt some of the plastic on pins 6 and 8, to have the wires nearer to the pins]
After that, the transformer started to works perfectly, measured also its winding DC resistances, completely in specs.
3] Adapting a 961/962 meterbridge
In this topic I've documented how to 100% use the features of a 961/962 meterbridge in a 169/269 console.
« Last Edit: September 29, 2012, 08:29:38 AM by 1954U1 »
jans
« Reply #33 on: February 21, 2013, 02:31:55 PM »
hi roginator,
i like the project. i own and use one as well. only i use the insertion out to go to my convertors. what is the difference in your mod? and where is the physical output then?
thanks,
jan
Cosmonaut
« Reply #34 on: September 22, 2014, 07:32:44 AM »
I have just the same problem with one of the line transformers in my Studer 169, I have opened and I can see the wires coming to the pins in number 6 , 7 and 8, but I can not measure nothing between 8 and whatever other pin.
 I should have a low resistanve between 6 and 8, no? am I missing something or just I have to solder it again?
Cosmonaut
« Reply #35 on: September 22, 2014, 10:06:53 AM »
I can see the wire on pin 8...but should be shorted inside the winding, my component tester and multimeter couldn“t measure any resistance on this pin.
« Reply #36 on: December 09, 2020, 01:39:19 PM »
Hey guys,
anyone had success in finding the edge connectors for the extender cards in one of the online stores or somewhere else? Looks kind of normal, but none of the big suppliers has these special 10+3 contact edge connectors in stock. Also I don't have enough unused one in my console, to build 3 extender cards, that are needed for calibration.
Ray
Whoops
« Reply #37 on: December 10, 2020, 02:41:04 PM »
on i/o modules REPLACE R47 trim !!!!!!!!!!!!
it make big difference on REV SEND, and output of each module in db!!!!!!!!!!!
that RUWIDO are BAD!!!!!!
What difference did you noticed?
Whoops
« Reply #38 on: December 10, 2020, 02:42:30 PM »
still have to demagnetize transformers on modules and mod it for direct output!!!!!
I never heard about these in older modules, is that a common procedure?
How do you perform that?
Thank you so much
« Reply #39 on: December 11, 2020, 10:09:37 AM »
Hello
Thank you so much
Have a look at section 2.6 and 7.4 in the service manual
Best
Zam
Last post January 16, 2007, 03:21:17 PM
by q2audio
Last post July 24, 2011, 09:28:09 PM
by ethervalve
Last post January 15, 2012, 02:01:04 PM
by amorris
Last post April 15, 2018, 07:41:03 AM
by zamproject
