Re: 69. Not Helios/Phaeton. Pics/schematics/building support thread.
« Reply #100 on: August 02, 2010, 08:17:56 PM »
Hi people, thanx for your support. I read the mails, please bit of patience,
there will be working solution.
/I double-checked my EQ, the only prob is LO CUT section/.
I fixed it with dual (2x12) switch.
Working now on sourcing right switches, sorry, have some busy days,
but fixing this thing is on my first priorities. Will inform here and by mail.
http://www.ij-audio.com
(new site hopefully will be up in July)
leadbreath
« Reply #101 on: August 19, 2010, 08:41:09 AM »
hey igor,
im just sourcing parts for the 69 psu and having a hell of a time finding a 1700uf electro cap, will using 1500 or 2200 be ok??
f**k marlbro's and weed ill stick to smoking germanium and silicon
ultra-alex
« Reply #102 on: August 19, 2010, 03:52:57 PM »
which cap are you talking about?
« Reply #103 on: August 19, 2010, 05:38:47 PM »
The big cap on Igor's powersupply pcb?
Is the problem  with the low cut already fixed?
« Reply #104 on: August 19, 2010, 08:01:57 PM »
I fixed it on my EQ. Now sourcing right switches. Please some patience.
ultra-alex
« Reply #105 on: August 20, 2010, 03:21:24 AM »
does igor provide different psu pcbs for the 69 lately? i thought those are the same as 2245/33609. if so, and you´re talking about C1, it´s a 4700uF...
http://i251.photobucket.com/albums/gg291/diy33609/POWER_SUPP_33609.gif
http://i251.photobucket.com/albums/gg291/diy33609/ps.jpg
« Reply #106 on: August 20, 2010, 05:37:57 AM »
That's right, but if you have a fast look at it, it looks like 1700 uF.
Thanx,
I was wondering if I could continue soldering in the mean time or if we do need new pcb's.
leadbreath
« Reply #107 on: August 20, 2010, 06:02:53 PM »
aahhh, thanks a lot guys much appreciated.
mick
ultra-alex
« Reply #108 on: September 05, 2010, 04:03:26 PM »
any news, igor?
« Reply #109 on: September 07, 2010, 10:28:28 PM »
Yes. Sorry, it will take some time, but I do't want to cut the pcb's.
The solution will be ellegant as possible in this situation.
In my first priorities.
More-after local holidays.
glazunost
« Reply #110 on: October 03, 2010, 06:05:49 AM »
Hi Igor
I finally found time to start building my two kits. Are there any news regarding the low-cut issue? I can find different infos when i skim through the various posts but am confused at what point the solution now is. Should i contact you via mail for replacement switches? I guess you had problems ordering them. Or can i just order the right part at mouser myself? If yes what is the correct type or part number?
Thank you very much in advance
G
ultra-alex
« Reply #112 on: October 05, 2010, 10:31:47 AM »
any news, igor?
Any news, Igor?
any news, igor?  ;)
jandoste
« Reply #113 on: October 05, 2010, 12:54:17 PM »
any news, igor?
Any news, Igor?
any news, igor?  ;)
I am waiting for two kits Igor !
PS : Did you get my mails about 2254C problem?
« Last Edit: October 05, 2010, 04:22:15 PM by jandoste »
glazunost
« Reply #114 on: October 13, 2010, 09:51:05 AM »
Hi Igor
Just read the main thread, i wish you all the best and hope you will soon be fully recovered!
Thanks again for making this project happening, it's awesome.
g
ultra-alex
« Reply #115 on: October 26, 2010, 05:03:35 PM »
any news?
« Reply #116 on: October 26, 2010, 06:10:33 PM »
Yes, please allow 5-12 days to check everything is 100% up.
« Reply #117 on: November 08, 2010, 07:30:02 PM »
Pending on how to solve the low cut problem..., I'm thinking of using a transformer at the input signal with a 1:1 ratio, as the original. My question is if I worked well with both make-up cards, the BA283 or perhaps better hel_amp?
On the other question, could explain a little more about the make-up card hel_amp? I have no very clear as to launch this card ... What transformer can work well on the way out? In the PCB there are pads with FBG and F.B., where they connect these?
This is an exciting project!
ultra-alex
« Reply #118 on: November 14, 2010, 05:39:47 AM »
bump...
« Reply #119 on: November 14, 2010, 08:11:39 PM »
I know. Very soon.
Helios thread
Started by « 1 2 ... 14 15 » The Lab
Last post December 30, 2020, 07:12:28 AM
by vitopower
Last post October 18, 2020, 10:36:55 AM
by andre tchmil
Last post October 20, 2012, 05:18:37 AM
by Whoops
Last post October 01, 2020, 02:12:56 PM
by Strat96
