550B schemos?
QUEEF BAG
Seattle
i find myself in need of a schematic for a 550B
the only schematic i have found so far is a hand drawn
doc that only has the audio path. (and a bit harder to follow than
a regular schemat)
With A-2 in the -16 volt rail falls to about -1.3v
take out the op amp and volts are good.
same thing with a new op amp too.
also still looking for a schemo for the (evil) 550A-1
thanks
here is a 550A, it's not the same but close enough it might help you.
thanks pucho-
i have quite a few api schems, including that one, & i guess yer right
i'll just use that one.
i'm sure we all could dig those other two though
as a somewhat avid collector, still havn't seen the A-1 drawing
as a somewhat half assed tech i could use them
wow. that all sounds rather lazy of me.
i hate it when i find my self procrastinating on some pieces,
& it's probably worse the better you are at rationalizing with yourself.
ok - back to the shop.
Curmudgeonly, your post makes me want to find every other product with the designation 550-B, since you made me figure out what the f&% you were talking about by not saying API.  No, I have no info.  ;)
yeahhh....i kinda thought about that, shoulda gone w/my gut feeling.
550B is up and running again, only needed a new op amp.
550A-1 is still down about a dB or two with the eq in circuit.
haven't gotten into API repair much until the last year or so and
am a little slower than i should be.
Doug- it would just be stuff like cessna aircraft,coleman stoves, kawasaki motorcycles,
ammo loading machines, 8 ton crawler/dozers, samsung software, air circulators, etc.
walrus-
yeow! fantastic!
thanks, those seem to be some of the harder ones to find,
been lookin' for a while.
i was a little suprised to see how much the revision E eq that
was on my bench looked like the 550L that is in the legacy consoles
thanks again
pucho812 said:
I have noticed that those 2520 have a high faliure rate, More often then not I have fixed api issues by replacing those DOA
In most older units there is not a lot else to fail!  :)
yeah, if you think those are bad, The original black 2510 op amps in the legacy eq
suck pretty hard, in a hot environment the little pins separate from the circuit board.
they make blue dipped ones now that seem to be lots better.
There's the Urei 550 for one:
http://www.uaudio.com/webzine/2005/may/graphics/analog%20obsession/550-A-close-up.jpg
Certainly far fewer of them out there, but that tends to be the stuff I obsess over.
