echorec said:
Hi Sleeper,
Thanks for the reply. I will do the same with the connector. I have not really started with the amp yet but it is good to know that I should not try to rebuild if I hear a little noise. When you say noise, do you mean "regular" noise or 50/60 Hz hum?
I mean regular noise, and by a little I mean very little, but If you are used to the improvements you can get by recapping/restoring a guitar amp it can be unnerving.
It's been a while, what I remember is:
Raising the bias didn't do much.
Shielding the wiring to the front panel controls helped a bit.
I shielded the case under the amp.
I put in a separate AC on/off switch rather than having the AC switch stacked on the back of the volume pot.
This was pretty useful
you'll see a few parts on the schematic that are variable, by the tremolo section. I tried a bunch of different stuff there, I definately found a sweet spot with those parts, try using a trimpot if you can, at least while you are adjusting...
I tried all metal film resistors, I put some of the carbons back in, I tried different types of capacitors.
I only found a few other amps with those tubes... whats it, a 6K11 something like that... I think there's an ampeg that has that. and the output tubes are also not too common either, but I got a nice matched set. EH I'm pretty sure.
Good luck with it.
