Dr nEon
Hi Guys!
I'm recapping (& de-mouldseal-ing!) a lovely old 'Bird Golden Eagle' valve guitar amplifier from about '64.
Things are goin well so far; New poly films,and some of the electros are done.Sounding good.
However ,I'd like some help/opinions on this :
There are a couple of Hunts wax paper tubular caps acting as a line to ground filter. They are both 10nF 350v AC ( 750v DC) rated . The two of these are in series, between the incoming Live line(at the mains switch), and chassis/ground.
If I understand correctly, this is effectively a 5nF capacitance with a 700v AC (1500v dc) max voltage rating.
I need to replace this with a modern Y2 cap , and this is where I'm stuck... I can find a 5nF (Y2) cap , but they only seem to be rated at 275v , or 300v AC.
Can I just use one of these ? I've been reading up on x & y type caps, and how they are designed to withstand spikes much higher than their nominal value , but I'd appreciate an experienced opinion on this.
I'm so used to replacing caps with the same, or higher, voltage ratings , that I'm hesitating on this one..
Cheers!
nEOn
Cheers!
nEOn
