Sounds like perhaps they were talking about Idss, higher Idss current generally reflects lower Rds.Ribbledox said:Hmm...I see...
Because I came over an article were they were testing two different JFET's, one with low drain current (same as high load impedanc, I gues) and a second with a higher drain current. And the second one turned out to have a much lower Rds (on).
So I though that perpahs the value of drain current (load impedance) plays a part in how low the Rds (on) may reach.
Also, the second JFET also had a much lower pinch-off point.
Cheers!
merlin said:Dragging up this old thread, to ask:
Does anyone know of any really low rDS(on) JFETs in an SOT 23 package, now the SST109/J109 is going obsolete? (The 109 was rated for 12 ohms max)
Indeed you can enjoy a slightly lower Rds that way, but be careful to keep the gate diode cut off or that DC diode conduction current will flow into the DS channel likely corrupting DC voltage for gate/mute applications.PRR said:> maximum Gm is at Vgs = 0.
Actually, you can go a little positive. JFETs don't draw grid current until many tenths of a volt "forward" bias.
> Be care: Maximum Gm is parameter of saturated (pentode) region, Not small - signal triode. But Rdson is parameter of triode region. Your "nearly the same" can mean "diferent twice".
Yes, you are correct. My quick answer is not correct for FETs in the triode range; Rds will be higher in the triode range. Thanks for the reminder.
However different FET designs, from fat switches to low-leakage amps, may have a 10:1 difference in Gm or Rds. When Rds isn't specified, Gm leads you to the better (for this use) devices and gives you an approximate idea of how much you can attenuate.
PRR said:At Mouser, these through-hole low Rds JFETs are listed in stock:
IFN5432 - 5r
J108 - 8r
IFN5434 - 10r
J110 - 18r
2N4856, 2N4859 - 25r
