Hello guys,
I actually working on an old project, the what compressor fabio's version (V2 boards).
Actually i run it unbalanced and with ic opamps for testing. If i'm satisfied by the way this compressor work i will upgraded it with input transfo and DOA in place of ics. I only use the treshold and gain pot and the sidechain filter switch.
The problem is compression dont work. Gain stage work well but treshold stage seems to be inactive. And the yellow compression led dont light up.
I run it +18v -18v. I check the voltage and adjust the trimmers. Everything is ok. I have the good voltage for each opamp. J1 and sc filter switch are in place.
When i look the compression section on the fabio shematic, the biggest difference with original shematics from Deet's is the option for attack and release pots. I dont use these but i mount RR1 that not figure in the Deet's shematic. Maybe it's the cuz of my problem.
Edited with the good fabio shematic
Fabio shematic here : http://www.fileshost.com/download.php?id=D7E517F71
Deet's shematic here : http://dt.prohosting.com/hacks/what1.gif
I will try to work on this when i'll back home (at the moment i compare shematics at job place...) but if anybody have the solution to my problem, your welcome !!
Guillaume
Guillaume
